my rendition of a carbed 383
nothing fancy, left all the computer wiring and sensor plugs, out of the box 750 double pumper, can mat it from idle and pulls like a freight train
trying to see if i can rig up the factory air inlet to pipe some fresh air into the air cleaner, i'am guessing high 12's maybe better....already has 3600 stall and 4.10 gears
Transmission: 4L80E/4L80E
Need more details: Heads, cam, intake.
I sure hope you can hit high-12's. My stockish LS1/4L60E with stall, gears, and headers does that at altitude. 12.0's at sea level.
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: my rendition of a carbed 383
I loved my 383, and quite frankly I'd still be driving it had the bottom end not failed. Main bearings went bad, no oil pressure. I think I may have been stretching the main bolts, given they were ancient stockers.
I ran a 7.42@92.89 in the 1/8th with a 383, Dart Pro 1 heads, RPM Air Gap, and Comp XR288 hydraulic roller. A blast to drive with the T56 and 4.11's.
I've since gone LS1 and love it, but I miss the brutal 3rd and 4th gear pull my 383 had. I guess a head/cam upgrade will fix that!
Andrew Prakash
Sep 8, 2015 11:48 AM
