Need advise
Old Feb 25, 2012 | 11:38 PM
modifiedman2's Avatar
Need advise
Hello i am new here but not new to cars. I recently did an engine swap in my 1987 firebird. I put in a first gen 350. The problem i am having is the front of the oil pan is hitting the center link and the Right tie rod end hits the pan whenturning to the left. Is this a normal problem or do i just need new mounts. Thanks
Old Feb 25, 2012 | 11:48 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Need advise
was it a v6 car? did you move the mounts?
Old Feb 25, 2012 | 11:50 PM
Re: Need advise
no it was a v8 car and no i did not move the mounts
Old Feb 26, 2012 | 12:04 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Need advise
Sounds like the engine is sitting too low. New mounts are cheap enough to try to fix the problem, certainly won't hurt and are necessary, irregardless of your problem, in a 25 y/o car.
Elephantismo
Feb 13, 2019 12:51 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
bryanwood74
Sep 24, 2015 09:50 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
stalkier
Aug 21, 2015 01:54 AM
