409 in a Camaro?
Old Feb 27, 2012 | 12:08 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
409 in a Camaro?
Would it fit? Has anyone tried this?
Old Feb 27, 2012 | 12:35 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 409 in a Camaro?
Which 409?
The ugly early BBC version ?
Better question would be ;Why would you want to?
Old Feb 27, 2012 | 03:51 AM
383 Power's Avatar
yeah, the old ones. I happen to think that it's a beautiful engine.
Old Feb 27, 2012 | 05:19 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
The 409 is an awesome engine. I say try it. Shouldnt be too terribly hard. Same Chevy bellhousing, same Chevy motor mount locations.
Old Feb 27, 2012 | 07:13 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
410Hp with twin carbs ,380Hp with a single
You can get that easy from a 383 with less weight and no fitting problems
Old Feb 27, 2012 | 07:45 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Yeah, but what fun is that?
Old Feb 27, 2012 | 08:41 AM
72vega's Avatar
yeah, unmodified.
Old Feb 27, 2012 | 12:35 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
What is the going price on a 409?
How much more money do you have to put into it to make 500 hp?
I think it would be cool to see, but this is another one of those times when you will be paying more and getting less, all in the name of being different.
Old Feb 27, 2012 | 03:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've always thought the 348/409 valve covers are the coolest looking out there, even moreso than hemi's.
The engine design is unique in that the combustion chamber is formed completely by the piston and cylinder - the head is flat with the valves in it, no further shaping by the head. Some innovating hot rodders have gotten some pretty decent power out of those engines, but it's mostly through custom-built parts. There's a local good-ol'-boy racer here who has a tilt-front solid axle '55 with a blown 348 that runs in the high-9's - at altitude, mind you. He runs 348's because 409 blocks are getting hard to find. Another has a '62 Impala 409 with 454 crank, dual AFB's, solid lifter cam, basically a street car that runs 12.7's here. Yes, cool, but as hinted at, a 383 could do it as well (a 454 would do it easier - and it's not a whole lot faster than my stock-internals, no-tune LS1).
But, all that being said, this would be 99% "cool factor" build, not performance per dollar by any stretch. Exhaust will be 100% custom built. There is some aftermarket support (like aluminum heads), but nothing like Gen I/II/III SBC, or BBC.
Oh, about "ugly" - the distinctive of the W-engines is the heads/valve covers. Other than that, they're just a cast iron engine like SBC's and BBC's.
Old Feb 27, 2012 | 03:31 PM
skinny z's Avatar
I have a complete 409 for sale if anyone is interested.
Carb to oil pan with exhaust manifolds (and trans) from a 61 Pontiac land yacht.
It was yarded out in running condition and has been stored indoors for the last several years.
Old Feb 27, 2012 | 03:55 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
I would say the 409 is an iconic motor but dated for a Camaro. I would rather see the 409 go into a 61 Impala than a thirdgen Camaro. Trade the 409 for a 427 or 454 - that would be a cooler swap. I just love the old Impalas with a 408 bench seat post body with 4 speed. My personal opinion is where that motor belongs.
Old Feb 27, 2012 | 04:05 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
They are boat anchors - they stopped making them for a reason - the BBC is better in almost every way.
Old Feb 27, 2012 | 06:58 PM
3rdgenmaro's Avatar
Car: 88 IROC
My thoughts exactly.
My dream car at this point is a 59 Biscayne. In reality it will probably end up with a 5.3 swap, but I would love to have a 409 to swap into it.
Old Feb 27, 2012 | 09:46 PM
383 Power's Avatar
Yeah, the 409 IS a very Iconic engine and it's VERY expensive. The whole reason for putting it in a third gen? It's the "Cool Factor" as Five7kid suggested. I was shopping for a crate engine on Ebay and saw a 409. I wanted to see if anyone had done this. I'm guessing that a 409 would be more likely in a first gen though. I'm sitting here in Bagram, Afghanistan dreaming about what i'm gonna do to my '82 when i get home. You guys help me keep the dream alive. I'll probably put a 383 in it after all anyhow, but it's nice to dream. Maybe i'll get a 409 anyhow and build it up nice. It'll be good for a second engine at a time when i'm bored and ambitious.
Old Feb 28, 2012 | 02:38 AM
72vega's Avatar
i wanted to build one for my old 88 chevy p/u so ive researched it... heres a good source of parts and info. http://www.lamarwaldenautomotive.com/
edelbrock makes aluminum heads and world makes a (very expensive) aluminum block also..
Old Feb 28, 2012 | 03:55 AM
383 Power's Avatar
WOW! you could run into some MONEY doing that!
Old Feb 28, 2012 | 08:06 AM
skinny z's Avatar
Check out 348-409.com
Old Feb 28, 2012 | 08:43 AM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Giddy-up Giddy-up 4 0 9
She always turns in the fastest times...
Old Feb 28, 2012 | 04:43 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I want to say 2 things,leave the 409 for the early iron where it will be most beneficial,and thank you ever so much for your service to our country.I for one deeply appreciate you.
Old Feb 28, 2012 | 06:18 PM
five7kid's Avatar
Would I do it? No. Because I'm a function-over-form guy. But, I can see this before a Duramax or Ecotec or a dozen other off-brand swaps that have been proposed in this forum.
As it is for anyone on this Board - it's your car, your money, your time. Just do it right - and finish it - if you go for it.
Old Feb 28, 2012 | 10:06 PM
383 Power's Avatar
Thank you Irockz. and yes, I'm kinda being swayed against the 409. I still think it would be cool. Drive up to the pump and someone says "Whacha got in that thing?". It would be nice to respond, "A 409".
Old Mar 4, 2012 | 05:52 PM
ChristianZ28's Avatar
Car: 82 Z28
Engine: broke SBC
Transmission: 700R4, 2800-3000 stall
Axle/Gears: 7.5...,4.11..till it explodes
Yeah to bad 90% of people would not know what it was.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
