305 tpi to 350
Old Mar 8, 2012 | 11:28 AM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
305 tpi to 350
I currently have a 305tpi I found a 350 out of a 91 Camaro for 200 almost complete,if I do a carb conversion what all is involved, as far as wireing and transmission shift and things of that nature? I mee all the help I can get before I do this so hit me with everything you know
Old Mar 8, 2012 | 11:45 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 305 tpi to 350
Old Mar 8, 2012 | 12:57 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: 305 tpi to 350
There's been hundreds if not thousands of articles and threads on the subject, just need do to some searching and I'm sure you'll find what you're looking for.
Old Mar 8, 2012 | 04:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The basics are covered in the tech article on the topic, which is linked from the thirdgen.org home page, and in the "welcome to the carb forum" sticky in the top section of the Carburetor forum.
The other details can be found with a .
Personally, if I had a TPI car, the ONLY reason I would consider converting it to carb would be if I trailered it to the track. Even if the 350 originally came with a carb. That, in my opinion, is the best help I can offer you with everything I know.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
