5.0 auto to 5.7 5spd swap help
Old Mar 9, 2012 | 09:44 AM
madigidy's Avatar
Car: 89 iroc z restoring
Engine: from 5.0 to 5.7
Transmission: from Auto to 5spd
Hey guys, I need a little help. I just had my drive train, from my 87 i-roc w/5.7- 5spd and had it installed into my 89 i-roc which used to have a 5.0 w/ auto. So the swap included (engine, trans, along with their harness). I also swapped the pedals and the E.C.M. once everything was in we got no ignition. We only have lights. Both cars ran before the swap. We then noticed that the 5.7 car had a chip in the key so we swapped the steering column. But how likely is it that we may have to replace the dash harness as well. Or has anyone done this swap and had this problem?? All help is appreciated.
BTW is there and thing that can be purchased that can be added to the harness at the fire wall so the engine can communicate with the computer like they have for LS conversions. if the harness is the issue.
Old Mar 11, 2012 | 06:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 5.0 auto to 5.7 5spd swap help
No ign (spark ), no crank or no start?
All different problems
VATS
read
https://www.thirdgen.org/vats_passkey_system
you need the VATS module and it's wiring under dash
or get VATS deleted on the prom
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
