305 TPI with a 700 R 4 swapped to a 350 TPI with a five speed manual
Guest
Posts: n/a
i have an 86 Iroc z camaro that originally had a 305 tpi and an automatic transmission and i have swapped it to a 350 tpi with a t5 manual transmission i was wondering what kind of issues that i may run into and if anyone knows how to remedy those problems. thanks for any solutions that i can get.
Re: 305 TPI with a 700 R 4 swapped to a 350 TPI with a five speed manual
The T-5 will do just fine if you drive it REAL EASY: no traction, no burnouts, no clutch dumps, no speed shifting. It might last a hundred thousand miles. Do any of those things though, and its lifetime will likely be measured in milliseconds instead of thousands of miles.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You need a 350 knock sensor , 350 injectors and a 350 prom in your 305 computer
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I did the same swap in my IROC. The t5 has held up fine so far, including a couple trips to the drag strip every year, with a best of a 13.6@101. I'm going to tempt fate and keep the t5 after the vortec head swap.
Some t5s break right away, others hold up if the motor is mild and you don't thrash it. I use mine, but I don't abuse it.
In terms of issues, a custom PROM, proper injectors, and a 350 knock sensor should do it.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
