L31 help!!!
Old Apr 4, 2012 | 08:45 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
L31 help!!!
im buying an L31 engine off my buddy thats coming out of his 96 suburban. iv read some where that the 1500 engines are better to have than the 2500 engines but can i ask why and what the problem is and the difference is???. as far as i can tell its just a 5.7 350 vortec thats producing like 340 hp, correct?
Old Apr 5, 2012 | 06:43 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: L31 help!!!
IIRC, some of the 906 heads from the 2500 up trucks had hardened valve seats with a single angle cut valve. They tend to not flow as good in stock form.
A refresh with a 3 angle cut should negate all of that.
According to wikipeida, the stock 5.7 was rated at 255 hp. I know it aint 340 in stock form.
Old Apr 5, 2012 | 07:02 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: L31 help!!!
But the 2500 blocks are better because they are 4 bolt main.
Old Apr 5, 2012 | 07:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: L31 help!!!
Not that it matters at all at any horsepower level that a mostly stock 350 will ever produce.
Old Apr 5, 2012 | 07:42 AM
LilSki's Avatar
Car: 85 Trans Am
Re: L31 help!!!
Oh I know just stating that it is a better block in general. But yeah doesn't really matter even on a fairly wild build.
Old Apr 5, 2012 | 10:01 AM
Engine: L31 350
Re: L31 help!!!
The Vortec 5700 produces 255 hp (190 kW) to 350 hp (261 kW) at 4600 rpm and 330 lb·ft (447 N·m) to 350 lb·ft (475 N·m) of torque at 2800 rpm
Old Apr 5, 2012 | 10:33 AM
Jim85IROC's Avatar
Re: L31 help!!!
There is no stock automotive application in which the L31 produces that kind of horsepower regardless of what your source says.
Old Apr 7, 2012 | 10:09 AM
3rdgenmaro's Avatar
Car: 88 IROC
Re: L31 help!!!
If you are going to quote from anything, you need to read the rest of the paragraph to see exactly what it is saying.
You left off: "It is currently being produced as a crate engine for marine applications and automotive hobbyists as the "ramjet 350" with minor modifications."
Notice the piece about the Ramjet 350?
http://www.summitracing.com/parts/NAL-12499120
There is your 350hp application.
FormulasOnly
Jul 23, 2018 08:47 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
sandman92084
Sep 12, 2015 10:27 PM
L98GTA87
Aug 25, 2015 02:23 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
