bellhousing help plz.
Old Apr 13, 2012 | 01:36 AM
explorermw's Avatar
ive searched the thread and have found little. i have a 82 firebird that had a 2.6l origanally. with a saginaw 4 spd manual clutch fork.. i am putting in a built 350. so here is my question. i an 11" flywheel (168 tooth) clutch and pressure plate. will the larger diameter bellhousing fit or do i have to mod the trans tunnel. thank you in advance.
Old Apr 13, 2012 | 08:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: bellhousing help plz.
Why would you not use the 3rd Gen bellhousing that the factory installed ( with a 153 tooth flywheel )
No mods needed
Old Apr 13, 2012 | 10:31 PM
explorermw's Avatar
because i have the 168 tooth flywheel, pressure plate, clutch and bellhousing already. thats why i was curious. i have a 153 tooth flywheel but thats it and would have to buy the rest. so if i use the 168 flywheel that requires a larger bellhousing then i would have to mod the tranny tunnel?
Old Apr 14, 2012 | 02:43 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It'll fit. Odds are good that the bellhousing you have to fit the 168 will cause the fork to hit the floor.
(I'd go for the 153 tooth flywheel and keep the 82 bellhousing that fits it.)
Old Apr 15, 2012 | 03:38 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There was a reason the factory used the smaller 153 tooth setup
Old Apr 17, 2012 | 12:41 PM
jmd's Avatar
jmd
You should elaborate on that point instead of leaving others wondering.
Is the starter pocket that much an issue on the passenger side?
Old Apr 17, 2012 | 11:02 PM
explorermw's Avatar
so i did some research and found out that the 82 firebird came with a 305 in either a 168 tooth or 153 tooth flywheel. depending on the engine code. H or 7 so there should be no issue at all.
AUZ28
Oct 3, 2015 06:28 PM
InfinityShade
Sep 18, 2015 08:32 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
jtwoods4
Sep 3, 2015 05:39 PM
jtwoods4
Sep 3, 2015 10:19 AM
