T-56 Swap. Do they make a bolt-on hyd. clutch bracket?
Old Apr 24, 2012 | 10:12 AM
Herewego1986's Avatar
Car: 1986 Camaro Z28
Engine: 357
Axle/Gears: 4.11's 10 bolt
So I just finished swapping in a t-56 to replace my cooked t-5. The guy i bought the transmission off of already had it in a 1980 camaro so he included in the sale the adapter plate and a keisler 6-71 bellhousing. i ended up using what he gave me and it is all in the car now bolted up nicely. My only problem now is that the bellhousing doesnt have a place that I can bolt the hydraulic clutch cylinder to. I put a picture of a t-5 bellhousing on here to show you the part I need, its the peice that sticks out on the left hand side with two small through holes and the center hole for the clutch rod to go through. Ive been looking online for a bolt on one but I havent had any luck. I was wondering if anyone on here has ever came across what im looking for, or if they have ran into the same problem and had to make their own? Any info is appreciated
Old Apr 24, 2012 | 10:20 AM
Twin_Turbo's Avatar
Re: T-56 Swap. Do they make a bolt-on hyd. clutch bracket?
The T56 originally uses a slave cyl that bolts to the bellhousing with a spacer, it's a pull type clutch, your T5 had a push style clutch, the slave bolted to the front of it. So the question now is...what type of clutch are you using now?
T5
T56
Old Apr 24, 2012 | 12:53 PM
Engine: 357
I am using a push style clutch like the t-5.
Old Apr 24, 2012 | 03:34 PM
Twin_Turbo's Avatar
Whats a 6-71 bellhousing? 6-71 is a blower size designation, do you mean 621?? that's part of the casting number on a chevy 4spd bell for a 11" clutch. Those are all set up for a rod actuated clutch fork. Best you can do is buy a retrofit kit
http://www.novak-adapt.com/catalog/kit_hcrc.htm
Old Apr 24, 2012 | 03:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Don't most of the aftermarket kits utilize the hydraulic throwout bearing? I wonder if that Keisler kit is set up for that setup?
Old Apr 24, 2012 | 06:17 PM
Engine: 357
Sorry, my bad. a 621 bellhousing is what I have. So what your saying about the clutch fork I have on there now is that absolutely wont work with a hydraulic slave? And if so, why wont it?
Old Apr 29, 2012 | 04:05 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
You could use a concentric internal slave.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
cRoe4
Aug 7, 2015 08:46 PM
