383 build
Old May 1, 2012 | 04:28 PM
89blackm's Avatar
383 build
i have a 327 that id like to build up. im looking into making it a 383/388 and was wondering what all is needed to be done and if there are any full kits out there? any tips/suggestions will be great!! thanks
Old May 1, 2012 | 05:19 PM
evo-offer's Avatar
Re: 383 build
search:chevy 383 on ebay. you´ll find plenty of parts from rotating kits,ready engine blocks ect.
Old May 7, 2012 | 09:38 PM
89blackm's Avatar
Re: 383 build
i was told i wouldnt be able to do a 383 stroker with a 327 and would need a 350 block?? is this true, because i thought all small blocks are the same and thought id be able to use the 327
Old May 7, 2012 | 10:53 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: 383 build
Well the 327 has the 4" bore just like the 350, just a shorter stroke, so if you bore it 30 over and give it the longer stroke then you'll have a 383, basically, a 350 with a longer stroke is a 383 also a 350 with a shorter stroke is a 327, same bore size, just different stroke
Old May 7, 2012 | 11:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 build
Depends on the journal size of the 327. What year is the block?
Old May 8, 2012 | 12:18 PM
89blackm's Avatar
Re: 383 build
its a '65 block
Old May 8, 2012 | 12:25 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
Personally, id keep it a 327, but that might just be because I think theyre cool
Old May 8, 2012 | 12:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
its a '65 block
Small journal. You would need to at least have the mains turned down to fit the crank in the block. It could perhaps be done (not sure how the oil holes would end up), but I don't know of anyone who makes a 3.75" stroke crank with small journals.
Personally, I'd find a later 1-piece RMS roller-lifter-ready block and put a stroker kit in it.
Old May 8, 2012 | 03:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 build
Sell it to someone restoring a 65 Corvette and pick up another block.
Old May 8, 2012 | 06:07 PM
89blackm's Avatar
Re: 383 build
haha ive tried selling it a couple times with no luck so looks like its staying wiht me
Old May 8, 2012 | 06:13 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 383 build
Yeah small journal mains, get a newer block
Old May 8, 2012 | 06:55 PM
Re: 383 build
Why?
http://en.wikipedia.org/wiki/Sunk_costs
See this article for an understanding of the inner workings of your brain while you're making that mistake.
Old May 9, 2012 | 08:30 PM
89blackm's Avatar
Re: 383 build
Why?
i know how the brain works, thanks though.
Old May 9, 2012 | 08:56 PM
Car: 1971 Camaro
Engine: 427
Re: 383 build
According to "chevy parts interchange manual" the early blocks are not as strong, and as mentioned, you will need to get your crank mains turned down as well.
I think you would be better off finding a one piece main block and building it, IMO.
Old May 9, 2012 | 08:57 PM
Car: 1971 Camaro
Engine: 427
Re: 383 build
Old May 9, 2012 | 09:42 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
Why?
No need to flame someone for a personal decision he makes, it's not your choice and there's no such thing as a wrong opinion, it's ok if you don't agree with it but you don't have to be disrespectful to him
In not sure why my post was deleted and yours was not, both were equally unnecessary and completely disrespectful
Old May 9, 2012 | 09:45 PM
89blackm's Avatar
Re: 383 build
i was also wondering why yours was and his wasnt.... im new to this and was just trying to get some opinions... after the numerous ppl saying what would need to be done(in a respectful way) i have decided to not make it into a 383 and just keep it as is and go a different route with it...
Old May 9, 2012 | 09:56 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
I know, so why would anyone have a problem with that? People build 305s, put in 4 cylinder engines, put in diesel engines and big blocks in these cars, so why can't you put a 327 in one? Especially since a 327 is a classic engine that can make great power... People like that make no sense to me
Old May 9, 2012 | 10:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 383 build
Sofa is attempting to highlight a cognitive bias called the sunk cost fallacy which leads people to throw "good money after bad", not flaming.
Old May 9, 2012 | 10:09 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
I know and I see his point (which I don't agree with) but its the way he said it, no one will ever get a point across acting like that, simply saying "a different block might be better to start with, especially financially and time wise" then he would get his point across
Old May 10, 2012 | 06:28 AM
Re: 383 build
disrespectful
Sorry if helping someone understand why they are making a mistake, seems direspectful TO YOU.
I suppose I should just go ahead and let him be an "alternate winner" instead of offereing him some HELP pulling himslef out of his self-destructive mindset? It would be more "respectful" to act as an enabler for a bad idea, and watch him crash and burn due to bad decision making as a result of unclear thinking?
What is this world coming to anyway?
Old May 10, 2012 | 08:06 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
No, you're problem is that you are trying to help but in the wrong way, the best way to help would be to do it nicely, doing it the way you did will just make people completely reject the idea all together because you had to be a **** about it, I'm not saying your opinion is wrong, I'm just saying the way you went about expressing it is wrong
Old May 10, 2012 | 08:14 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 build
This... you get the nice feature of factory roller cam and that is well worth it IMO. More cam choices to make big power while having driveability. No worries about flat tappets wearing out due to todays modern oil, no additives needed, and smoother operation to boot. net cost is alittle higher but do it right and you'll never regret it.
Old May 11, 2012 | 12:39 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: 383 build
I would agree with you except for the dozens of others he has tried to help and they all want to basically say he is wrong (to put it mildly).
When I get ready to build a motor I hope to have his and a few certain others input (most have already chimed in here) as they seem more knowledgable and willing to help than many.
Old May 11, 2012 | 02:31 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: 383 build
Don't get me wrong, he is very knowledgeable and gives great advice, just sometimes has the wrong attitude
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
