1992 z28 engine swap qeustions
Old May 7, 2012 | 07:58 PM
toppgunn77511's Avatar
I have a 1992 z28 with 305 tbi motor. I bought a complete 350 tpi motor with wiring harness, ecm, and pass key box off a 91 z28. Do I need any other parts to complete the swap ?
Old May 8, 2012 | 12:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1992 z28 engine swap qeustions
TPI fuel pump for starters
Old May 8, 2012 | 02:08 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
If your chipped key is working properly you should not need the pass key box. If you do swap it out you may have to change your key chip to match that box.
Old May 8, 2012 | 10:03 PM
The key that I have when it had the 305 in worked just fine. I have the key for the 350 but I dont have the ignition cylinder
Old May 8, 2012 | 10:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if you use the key from when it has the 305 and the passkey module just run the vats hz signal wire to pin f10 of the 1227730 ecm
Old May 8, 2012 | 10:34 PM
Thanks, I hope my mechanic knows what that means. I paying for the swap lol
Old May 8, 2012 | 10:39 PM
Engine: Lb9
Transmission: M20
The memcal in the ecm is programed for vats, the old key and old passkey module are matched and will send out a 30hz signal to the ecm.
Old May 8, 2012 | 10:41 PM
so will the key from the 350 work ?
Old May 8, 2012 | 10:48 PM
Engine: Lb9
Transmission: M20
no the original key was vats it is matched to the passkey module in the car now. those two need to work together. There are a dozen resisters used in vats keys they match the vats module.
Old May 8, 2012 | 10:51 PM
I have the key and the pass key box from the 350. I didnt get the ignition cylinder from the 350 though, cause the person I bought the 350 motor didnt pull it
Old May 8, 2012 | 10:52 PM
Engine: Lb9
Transmission: M20
I would also only use a acdelco ep241 fuel pump for the conversion. Others have used cheap walbro black market ones and other chinese ones and had bad luck with them. If its your dime for the tank to be dropped do it once.
Old May 8, 2012 | 10:59 PM
acdelco ep241 fuel pump, is that the part number that I can give them at auto parts house ?
Old May 8, 2012 | 11:00 PM
Engine: Lb9
Transmission: M20
yes, It is a acdelco number make sure they are not cross referencing it.
http://www.ebay.com/itm/NEW-AC-DELCO...#ht_1957wt_936
Old May 8, 2012 | 11:13 PM
Engine: Lb9
Transmission: M20
another issue you will run into is the speedometer. the stock tbi uses a vss buffer. the vss signal on the transmission is 2k ppm and goes to a vss buffer from there it sends a 2k signal to the ecm. I am unsure if this is a optical or magnetic signal but you could try to run the buffer pin c tap off of that to pin b10 on the 1227730 ecm. The last few swaps I did I just reprogramed the memcal to a optical and used pin c6 on the ecm and use the optical feed from the buffer pin F. Another option is to get a 90-92 camaro vss and wire it directly to the ecm and the ecm has a buffer in it to feed the speedometer and cruise.
Old May 8, 2012 | 11:39 PM
hey so is the vats box and the key pass box the same thing ?
Old May 8, 2012 | 11:44 PM
Engine: Lb9
Transmission: M20
yes sir
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
