383 parts list and build
Old May 17, 2012 | 10:46 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Just got my block back from the machine shop, it was a '95 350 TBI from a truck, I got the cylinders bored .030 over, got the holes tapped for the spiders so it's now roller ready, and got it cleaned/new bearings/freeze plugs and all that basic stuff
Parts list:
Scat 9000 series 383 rotating assembly (cast steel crank, forged rods and pistons, plasma ductile rings, 9.8:1 cr with 64cc heads)
OEM roller cam assembly (kit includes spider, dogbones, lifters, and bolts)
Not sure on pushrods, I need to measure for the size I need when I get the cam
Comp roller cam (.560/.560 lift w/1.5 rockers, 230/230 dur. @.050, 110 lsa)
Patriot performance vortec style heads (185cc 2.02 valve intake, 60cc (?) 1.60 valve exhaust, 64cc chambers)
Edelbrock RPM air-gap vortec style intake manifold
Holley 770cfm 4-bbl carb (elec. choke, vac. Secondary)
Hooker headers with pipes running back and turn out right in front of the rear wheels
3.42 posi rear
Rebuilt 700r4 with a reverse manual valve body and b&m ratchet shifter
I think that's all I have planned for now, engine/drivetrain wise anyways
Id appreciate anyone's input on any of these parts or combination of parts and this will turn into a build thread in about a month, this is going into a 91 RS with a 305 and it will be taken to the drag strip multiple times per year, but not in any really big events
Old May 23, 2012 | 10:32 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: 383 parts list and build
drag strip? Not sure
Street? Should be fun.
Old May 24, 2012 | 06:11 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
It's gonna be about 80% street, 20% drag racing, but jut like some Friday night grudge matches against some buddies, nothing major
Old May 28, 2012 | 02:45 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Have you bought all the parts yet or are you still just planning? That's the big question right there IMO. I'd do some changing around if you could.
Old May 28, 2012 | 05:44 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I can still change the parts, what do you suggest?
Old May 28, 2012 | 05:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not super familiar with the Patriot Vortecs, but unless the exhaust ports are significantly better than stock vortecs, you're probably going to want a split pattern cam.
Old May 28, 2012 | 06:50 PM
1gary's Avatar
My selected parts list on my 383 build:
1995 L31 roller block
.030 over
5.7 rods Scat rods profiled for stroker with 7/16 ARP bolts
3.75 Howards track smart crank
Icon 18 dished pistons
decked 10 down
World S/R heads 67 cc heads with 170 intake runners.
Static compression ratio 9.2
Hyro roller cams being considered:
GM part number 14097395
288/308 duration @.050
196/206 with rocker ratio 1.5.1
431/451
Lobe centerline 109
OR
Erson cams
Part number E11980
Rpm range 2200-5200
Duration 272/280
Duration @.050 218/226
480/480 rocker ratio 1.5.1
lobe center 108
OR
Part number E119847
Rpm range 2500-5500
Duration 286/294
Duration @.050 226/234
548/540 with 1.5.1 rocker ratio
Lobe center 112
Old May 28, 2012 | 10:38 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Jim- what would you suggest with the cam? This is just a recommended one from comp that I'll base my choice off of
Gary- I guess the cam you end up choosing will be decided by how you're going to use the engine, and you're parts aren't too different from mine, the only thing I would wanna change with yours would be the heads, I'd prefer a 64cc chamber to up the compression (my goal is around 10:1) and maybe a little bigger on the intake runner, the worst thing is building an engine with great potential but not letting it get to its full potential because of a restrictive intake and exhaust
Old May 28, 2012 | 11:02 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
How often do you plan on going to the strip? What kind of budget are we talking? I'd change quite a few things if it were me.. if you're wanting good numbers at the track, anyways. What are you doing about your converter?
Old May 28, 2012 | 11:04 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I wanna say only 2 or 3 times per year, I not too worried about getting amazing times at th track, just respectable times, and I'm glad you brought that up, I have no clue what converter to buy, I'm clueless when it comes to those
Old May 28, 2012 | 11:05 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Oh and budget, I'm only 18 so im living with my parents, I do have a full time job and about 2k saved up for the engine right now, so there isn't dealt a set budget, it'll be a "buy as I go" thing, but I don't want to spend crazy amounts of money
Old May 29, 2012 | 12:47 PM
Jim85IROC's Avatar
I would check with the Patriot guys to see what they say. They will probably have the best idea of what works best with their heads.
Old May 29, 2012 | 01:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah I'd probably open up the exhaust side duration abit more. Lobes are good just need a longer exhaust side. 230/236 or so. Else the power will likely fall off abit at peak rpm instead of holding on abit to extend the shift point/rpm range. you can stick with the magnum lobes just have them put a larger exhaust version on.
Old May 29, 2012 | 10:53 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Will do
Old May 29, 2012 | 10:55 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I'll definitely do that, thanks guys
Old May 30, 2012 | 07:24 AM
1gary's Avatar
The flip side of that is keeping the intake runner on the small side to tailor a torque curve earlier at a lower rpm.More useful in normally used rpm's on the street so you do get a better return on your investment.
Old May 30, 2012 | 07:33 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
That's true, i guess it all depends on how youre going to be using your car, 170's will be good for the street, the reason i don't want to go with 200+ cc runners is because i want to keep the powerband lower, but still have a decent track time
Old May 30, 2012 | 07:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It really doesnt take much power to move a car, and normal street driving in my opinion, under half throttle, it really doesnt matter what low end you have. You will have a higher stall rpm converter to make up for lack of low end and should have enough gearing. If manual, run more gear. You may feel a difference but how much power do you really need at lower rpms for street driving?
I realize this now after doing my turbo build... off boost the car is a turd, wont even spin first gear with a WOT mash. pretty crappy for 400" of motor and good heads/cam setup with high stall...but the power is PLENTY enough to move around...more so than most 4 cylinder daily drivers out there.
For a 383, 190-200 cc runners are a great size. The stroke will make plenty of low end and midrange to get you into trouble if you arent careful.
Old May 30, 2012 | 08:01 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Ok, ill look for something with a little bigger intake, but I've never heard anything bad about these heads, and you can't beat the price either, i want to go with vortec parts to lay down a bunch of torque with the engine
Old May 30, 2012 | 08:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You dont have to go bigger, those heads should do fine but just saying, dont make the mistake of going to small because of fear of low end. A 383 will have plenty
Old May 30, 2012 | 03:11 PM
1gary's Avatar
Actually I moved up to 180cc heads.The point I am making is a lower torque curve and building off the natural aspect of a stroker which is torque.That hp for all too long has been over sold to the public and is over rated for street vehicles.The other point you see in my build list is the purchase of a high quality Howards crank which will have no problem taking anything I throw at it.
Old May 30, 2012 | 11:18 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Well the reason I went with the 383 was for torque, that also why Im going with vortec style parts, but I also want to make sure when I do take it to the track that I will have enough top end horse power to run decent times
Old May 31, 2012 | 06:05 AM
1gary's Avatar
I hear loud and clear.One concern is to build a torquer street engine that acts like a diesel.A real bear on the low end,but a rock after 5,000 rpm.Falls on it's face!!.I won't deny you can build a engine solely for torque,but lacks hp.It's a trade off of sorts.Where by building hp your going to move the torque curve up the rpm range.Much of the build plan I suggest should be surrounding the compression ratio.It dictates cam selection for one thing and how high of a rpm you need to maximize output.It also is a main factor in hp ratings.I am not a big fan of Vortex heads.I do think they are a crutch between stock and true aftermarket heads like those from RHS.The main reason why I am such a fan of RHS is their yrs of flow bench R & D and their handle of true CNC machine port work.Just to have a company say they do CNC porting without the R & D isn't enough.You I suggest want to build a engine that has all matched parts to tune for a given goal.I do think as a guideline to remember the statement of go big or go home doesn't apply to all cases.Going to big as a example for a cam in a street vehicle requires often a bigger stall convertor which crates heat and trannies don't like getting too hot.So I am saying these choices should also account for the effect it has on the rest of the car in the build plan.Big picture!!.
The guys I really respect are guys the build a car that idles like a kitten and runs like snot.
The parts business really hasn't changed all that much.There is a line where race cars are race cars and true dual purpose cars are true dual purpose cars.There still is a line not to be crossed over.What we really did was improve the top haft with a better understanding of how it works.
Old Jul 15, 2012 | 11:03 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Hey guys, sorry about no updates but I've been real busy with the new job and I just bought a 2005 ram 1500 with the 5.7 hemi so I'm having fun with that, anyways, I have the complete rotating assembly just waiting for time to put it all together, I decided to go with the patriot freedoms series heads, aluminum, 2.08/1.60 valves, 190int/68exh runners and 64 cc chambers, I also think I wanna get a custom grind cam, I'm thinking .550/.565 lift, 232/240 dur @ .050, 110 LSA, what do you guys think?
Old Jul 15, 2012 | 11:19 PM
1gary's Avatar
Where does those heads leave you in SCR and take into account the DCR given that cam.Compression does dictate cam choices.
383's do like a long duration big lift on the exhaust side.
Old Jul 15, 2012 | 11:21 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
9.8:1, and I want to use a thin head gasket to get as close as I can to 10:1, so I won't need the cam to bleed off any compression
Old Jul 15, 2012 | 11:28 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I know the lift is enough, maybe a little more duration? I wanna keep the powerband 2500-5500 rpm
Old Jul 15, 2012 | 11:38 PM
1gary's Avatar
The other part of a cam choice is the convertor and if it is a EFI,they like a 112 lobe center or better.They tune easier with that.Now I am very sure me saying that is going to draw some posts because there are guys out there that are running 108's and had to work on the tune.BUT,at 110 or 108 your already accounting for buying a different convertor and the changes in a tune.So it costs you more.
Old Jul 15, 2012 | 11:39 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Well I'm using a carb, not fuel injection, and I am planning on buying a new converter but I have no clue what to look for
Old Jul 15, 2012 | 11:43 PM
1gary's Avatar
With aluminum heads you could go to 10.5 on pump gas.At that point it is a game changer in cam choices.But that would move the power band up.
Old Jul 15, 2012 | 11:52 PM
1gary's Avatar
I like many on this board would have ideas about which convertor to get.The best source for info on that is the cam manufacture or who is grinding your cam.You can take that advise as the bible.And because of that being the god's honest truth,I'm going to step back from a suggestion about that.
Dodge Hemi huh.I know a guy that has one,is always complaining about gas mileage around town.How you doing on the gas mileage??.
Old Jul 16, 2012 | 12:02 AM
1gary's Avatar
BTW-sorry about the typing speed.Between the arthritis and diabetics,it left me with what amounts to two claws to type with.
Old Jul 16, 2012 | 12:27 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Ehhh I try not to notice the mpg, I get like 15mpg combined, but I didn't buy a hemi for gas mileage haha and not a problem
Old Jul 17, 2012 | 10:54 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I know I could go up a little more with compression using the aluminum heads, but I think 10:1 should work well. Next purchase will be the cam and the OEM roller setup
evilstuie
Feb 28, 2016 03:33 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1nastygta
Aug 8, 2015 07:38 PM
