l98 (corvette heads) 383 combo with 700r4
Old May 19, 2012 | 10:12 AM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
Well kinda like i figured the transmission would crapped out before my 2.8 did so i figure now that my transmission's pulled i should go with a slightly mild (87 and up stroked and bored 350) 383 build with ported corvette aluminum l98 heads 1:6 rockers or 1:52 rockers with an LT4 hot cam and run the tuned port set up just to get a better feel than what the 2.8 offered. My only concern is getting a v8 700r4 and having it rebuilt with a mild stall and shift kit hoping the tranny holds up since i hear a stock one only holds a little over 350 hp. How much horsepower\ torque at the flywheel could i have with this combo, will the 700r4 hold up even after a rebuild and what kind of stall should i use, gear wise i'm running a non posi 3.42 rear right now if it makes a difference.
Old May 19, 2012 | 11:31 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Re: l98 (corvette heads) 383 combo with 700r4
Better steer clear of the vette heads. 58cc chambers on a 383 is going to give you an extremely high compression ratio. They don't flow any better than the iron L98 heads either.
-cal30sniper
lt500r55
Sep 1, 2021 01:30 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
