timing issues
Old May 19, 2012 | 11:24 PM
Marine_14's Avatar
timing issues
hey all,
i just swapped out a 305 TPI for a 383 stroker, ive gotten everything in and ready to go but i cant figure out the timing. im sitting TDC on the number one piston on the compression stroke and the striker is pointing dead on on the number one spark plug hole, after some turning of the distributer cap i got her to fire but she has no butt and when i put a timing light on her its about three to four inches away from the scale on the retarded side i just tore the timing cover off and im lined up no teeth off. what else can i do? any help would be greatly appriciated
Old May 20, 2012 | 12:21 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: timing issues
SBCs use 2 different balancer/pointers for timing. 12 oclock and 2 oclock. find true TDC and make sure your useing the correct pointer. heres a vid on timing,...hope it helps.
http://www.youtube.com/watch?v=UYGU7mTwsZc
Old May 29, 2012 | 03:31 PM
89blackm's Avatar
Re: timing issues
i having a very simular problem.... just dropped the motor back in and all i get is it turning over, only had it bark once and that was it..... checked the timing gears at tdc, made sure the rotor was pointed at #1 plug hole,plugs and wires connected(i have a 8365 msd distributor) help us!! haha
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
