GM 383 Vortec Engine
Old May 24, 2012 | 06:29 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Well I have developed what I believe is a rod knock in my 1992 Formula 350. Engine has a little more than 114000 miles. Great engine lasted under many blasts with 150 NOS. So I have been trying to make up my mind about what to put in its place. I wanted to do an LS1, then found a 1993 LT1 with 38000 miles for 1900.00 but someone got it before I did. I don't to spend a **** ton of money but have finally found my way to this.
This offer is a Chevy 383 stroker motor, with GM iron VORTEC heads. The block is a 350 with 1-piece seal, that recieves this machining: Bored and honed- Deck gasket surface- Grind for rod clearance with stroker crank. The VORTEC iron heads, feature 175cc intake ports - heart shaped 64cc chambers, for greater strength and performance. No core exchange required, saving you HUNDRED$$
This engine is built to order, taking appox. 3 weeks, after payment thru PayPal. The engine comes with a NEW 5qt. oil pan and balancer installed, along with a NEW (Satin or Polished finish) dual plane intake manifold. The engine will be painted the color of your choice, and comes with valvecovers of choice (Chrome plated steel - Black/red letters - Gray/blue letters- Polished aluminum).
The crankshaft is by "EAGLE" products, with 5.7" long I-beam rods and SpeedPro pistons with moly rings, giving pump gas friendly (10to1) compression ratio. A Comp Cams hydralic camshaft, spec's (232/232`@.050" with .480" lift) with matching valve springs, providing TREMENDOUS acceleration, with a power range of 2000-5700 rpm's.
This engine is hand fitted and assembled, by ASE certified Master Machinist (me), with 26 years experience. This engine comes with a 90 day parts and workmanship guarantee, after start-up.
Expect 425hp and 420 ft.lbs. torque, PERFECT for your CAMARO / FIREBIRD / TRANS AM / C-10 / S-10 / CHEVELLE / MALIBU / CORVETTE / VEGA / STREET ROD / IMPALA / BEL AIR / EL CAMINO / MONTE CARLO. This motor has serious power!
New LOWER price $2499.00 + freight.
So my question is what do you guys think. The seller is a well respected builder with a great rep. I know I will probably need a lower Vortec TPI manifold but will the cam work the stock computer. A chip I guess? Any comments or thoughts would be great. Also I will definitely be switching to a T56. Thanks.
Old May 24, 2012 | 08:48 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: GM 383 Vortec Engine
Seems like it has the potential to make about what he claims it will. Those are a set of stock casting vortecs I'd imagine with the 175cc runners. Only thing I am curious about is his decision to not use a split duration cam since the Vortecs respond very well to a larger exhaust duration.
I don't know much about the TPI years, always switched my stuff to carb. It will need to be tuned somehow; along with new injectors at the very least. I'd go with something like the HSR intake or else you'll fall flat on your face in the higher RPMs.
Old May 25, 2012 | 05:17 PM
PAFORM350's Avatar
Engine: 5.7 L98
I agree. I sent him an email and he tells me that with the TPI he is going to use a different cam. Something along the lines of a 224/230 with a 112LSA. I am wondering if I use the vortec tpi base and a set of ASM or TPIS runners how that would work. But I guess for the same price I could get the HSR as you mention.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
