Smog pump delete pulley belt set up
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I saw on here a belt routing for a smog pump delete which doesn't have the delete pulley. It said what belt to use but I can't find it now. It had pictures and everything. Could someone either send me a link to that thread non post it with pictures here or send me a personal message.
Also I am swapping from a 305 to 350 can anyone tell me if I can start and drive the car with the stock chip in it for a very short less then 20 miles distance?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Smog pump delete pulley belt set up
https://www.thirdgen.org/serpentine
If you are staying with tbi make sure you get larger injectors 55 lb/hr GM5235206
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
