TBI with ECM or Carburator
Old May 28, 2012 | 05:42 PM
djdsails's Avatar
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Hi
I have a TBI 305 engine. I wanting to do a build. Unfortunately I don't know enough about the TBI and the ECM.
What set up, carburetor or TBI with computer, will put out better numbers overall? Assuming I do intake, cam, and headers.
Basically, do I keep the computer and do the intake, cam, and headers with my current TBI or do I get a carburetor that has a higher CFM rating?
Another option is get a 350. Do intake, cam, headers. Put it in my car, get a new chip for the ECM and anything else required for the swap THEN, put my old TBI unit on top? Will that put out good/respectable numbers? Will the TBI unit keep up? Or go Carburator with this option?
Old May 28, 2012 | 07:13 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Axle/Gears: 10 bolt posi 3.08 gears
Re: TBI with ECM or Carburator
depends what your wanting it for id say go with the 350 ive never really heard of tbi for perfomance id go with a carb or maybe a tpi setup
Old May 28, 2012 | 07:16 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
if i can buy this lt1 off another guy on here and get it put in my car ill sell you my tpi
Old May 28, 2012 | 10:20 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I would recommend TBIchips.com. He is very helpful with the info, and can do a mail order chip for your car. If it ever needs a retune, he will do it for free. I had a hot chip programmed for my truck, and then I did a mild build after that. He reimbursed me the value of my chip towards the custom chip. He also does TPI.
Old May 29, 2012 | 02:50 PM
djdsails's Avatar
Car: 92 camaro RS
Is carburetor the way to go? is it where i am going to get the most out of my build?
Do i go with the current 305 engine that is in my car now? will sticking with the current engine reduce electrical problems down the road?
do i keep the computer or go carburetor?
i am having trouble making these decisions, otherwise doing the build and making the parts list is easy.
Old May 29, 2012 | 03:17 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
its your own personal preference no one can make the decision for you as far as the 305 goes i wouldnt build it id just go with a 350 and if you do all the electrical right then you shouldnt have any problems just do alot of research and talk to everyone you can but the decision is ultimately yours
Old May 29, 2012 | 03:20 PM
djdsails's Avatar
Car: 92 camaro RS
its electrical stuff that is bogging me down.
Old May 29, 2012 | 03:25 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
yea ive always been nervous bout it also but if you dont try then you will never learn
Old May 29, 2012 | 04:13 PM
djdsails's Avatar
Car: 92 camaro RS
tell me your thoughts on these articles. they are quite convincing
http://www.carcraft.com/techarticles...d/viewall.html
http://www.superchevy.com/technical/...d/viewall.html
Old May 29, 2012 | 04:31 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
im not gonna lie thats not bad for some 305s but you said you was wanting to do a build and even they said if your building something go with the 350 but if your really intent on the 305 then i wish you the best of luck and keep us posted
Old May 29, 2012 | 05:11 PM
Car: 86 Camaro Z28
I would say stay with FI for drivability. wiring is not an issue if it already is TBI. just put a 350 under it, the truck TBs can be found everywhere.
Johnoooooo
Sep 22, 2015 08:55 AM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Billy Decker
Sep 4, 2015 03:46 PM
