350 PROM chip not found anywhere
Old Jun 13, 2012 | 12:06 AM
spitfireIX's Avatar
Car: 87 Camaro
Engine: 5.7 TPI
Transmission: 700 R4
hey everyone,
i have a 1987 camaro IROC Z (tpi model) and i just swapped in a 350 (it was originally a 305), i heard that when you do this you need to swap the ecm and PROM with the 350 ones. i bought the 350 ecm today but i cannot find the 350 PROM anywhere. the dealer said they are disconnected but they could get me one for 480 dollars. oreilly has them for 353 but special order. i was wondering if there is any place online or in store that has them more available when i dont have a core or chip number to begin with. i already tried ebay and summit with no luck. also is there any aftermarket ones that come with the PROM not just an add on to the original PROM and if so would it be cheaper? i would prefer to use an original one but if i have to i will use an aftermarket one i will. any help is appreciated.
thank you
Old Jun 13, 2012 | 01:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 PROM chip not found anywhere
No such thing
The ECM used for 305 and 350 is identical ( for a given year) ;only the memcal / prom / chip inside that you are looking for changed
The actual tune is on the add on adapter so you could possibly use the 305 memcal as the " original " prom;
is mainly there for limp home mode
$100 here ;
http://pcmforless.com/index.php?opti...=109&Itemid=29
just tell them what BCC
http://www.chevythunder.com/prom_bcc_1987.htm
you want programmed
There are some members on here that may have the gear to be able reprogram your 305 memcal so you don't need the adapter
Send a PM to member tunedperformanc
Glowsock
Jul 24, 2025 03:15 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bjpotter
Aug 12, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
antares57
Aug 6, 2015 07:47 AM
