LS swap
Old Jul 20, 2012 | 04:11 PM
87350's Avatar
LS swap
im going to be swapping a 4.8/5.3 LS block into my 87.since its a truck motor the oil pan and accessories wont work for the swap. i was wondering if there are any other applications that i could get the parts from besides 4th gen camaros and firebirds? as soon as you say you need a part from an LS1 the price seems to double. thanks for any info!
Old Jul 20, 2012 | 08:38 PM
87350's Avatar
Re: LS swap
ok i see that i put this in the wrong section. sorry
Old Jul 20, 2012 | 08:50 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: LS swap
04-06 GTO also uses the same stuff
You could also use a complete corvette, or complete CTSV setup
You cant mix and match stuff outside of that, gto stuff is the same as f body, and ctsv and corvette share the balancer.
CTS-V and corvette are the most compact front to rear.
Old Jul 20, 2012 | 08:52 PM
87350's Avatar
Re: LS swap
well i can expand my search a little bit at least. thanks!
Old Jul 20, 2012 | 09:01 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: LS swap
GMpartsdirect.com for most of the stuff man, you'd be surprised how cheap this stuff is just buying it new for a lot of it, brackets are around $25 ea, my cts-v new ps pump was $100...
Old Jul 20, 2012 | 10:43 PM
87350's Avatar
Re: LS swap
yeah a good portion of my swap cost will be in the accesories since i have none right now. water pump,ps alt, tensioner and all the brackets plus oil pan and pick up tube and dipstik. probly gonna use stock ls1 manifolds cuz swap headers are an arm and a leg. thanks for the info!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
