auto to 5 speed
Old Aug 2, 2012 | 07:57 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
auto to 5 speed
Hello I am doing an engine swap and figured if i could do a 5 speed swap why not. I have a 98 camaro v6 5speed setup. Could i use all the linkages and that 5 speed with a v8? or would i have to put in reinforced gears?
Old Aug 2, 2012 | 08:21 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: auto to 5 speed
Someone needs to fill in the blank spots in my memory but as I remember here are the issues
98 uses a different bolt pattern for the bell housing similar to the ford
Input shaft is to long
I cannot remember if the spline count is different I know it is for 3.4 and smaller.
Also if I remember correctly the gear ratios would be really short for a V8
Old Aug 2, 2012 | 08:33 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: auto to 5 speed
you would be far better off getting a t56 from a LT1 and using that.
better transmission, and dual overdrives
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
