1989 firebird with LT1 engine
Old Aug 7, 2012 | 06:27 AM
blackhawk1840's Avatar
Hey guys I'm having some problems with my firebird. I bought it knowing I needed a new.fuel pump and I fixed it. It starts now but shuts off if I don't keep foot on gas if it idels under 1500rpms it will shut off. I also did spark plugs and wires and other things if anyone could give me some input that would be greatly appreciated. Thanks guys.
Old Aug 16, 2012 | 10:45 AM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: 1989 firebird with LT1 engine
check all of the ECM fuses, turn the key on and make sure that all of the power wires to the ECM are getting power, my ECM 2 fuse causes the same issue
Old Aug 16, 2012 | 10:52 AM
racethesunlive's Avatar
Car: '92 Camaro
Also check the ICM and the coil in the distributor, I had a stalling at red lights issue that was caused by either one or both of these being bad.
Old Aug 20, 2012 | 03:16 AM
Yeah its like my engines not getting enough gas to it but I will.check all these thanks.guys
Old Aug 20, 2012 | 07:03 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
have you checked the fuel pressure?
Just because the pump is good doesn't mean you have fuel pressure at the rails.
Fuel filter could be blocked for example
Also pull the engine codes and see if anything showing;
something else ( electronics? ) may be playing up
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
