block side motor mounts difference?
Old Aug 9, 2012 | 10:42 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
do you guys know if all the 350 block motor mounts are different? im asking because im going to be dropping my 96 350 from a suburban in my car soon and id like to use its original block mounts to save on cost and so i dont have to go get a set off a thirdgen. can i use the stock mounts and just change my k member motor mounts to the camaro ones?
Old Aug 10, 2012 | 03:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: block side motor mounts difference?
Engine mount bolt pattern on the block of all SBC is the same
You need a engine mount to suit the chassis the engine is going in as that is where mount style varies
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
