wiring harness
Old Aug 10, 2012 | 12:41 PM
sportcoupe-z28's Avatar
Car: 82 Camaro SC
wiring harness
im doing a v8 swap, currently have the 2.8 in the car, im putting in a carb'd 350. do i need to get a v8 wiring harness? or does everything match up?
Old Aug 10, 2012 | 03:47 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: wiring harness
You do not need to get a V8 harness. You may need to lengthen some wires for the bigger block but still no need for another harness. Just be sure to do a neat job on any wires that you need to extend.
Old Aug 10, 2012 | 11:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wiring harness
All a carb engine needs is Ign wire to the coil and wire to starter solenoid
( as well as the temp and OP gauge wiring )
Old Aug 11, 2012 | 08:34 AM
Car: 82 Camaro SC
Re: wiring harness
ok sounds great! i have one more question about wiring i despritly need help with, ill link it
https://www.thirdgen.org/forums/elec...g-problem.html
Old Aug 13, 2012 | 09:31 AM
91phoenix's Avatar
Re: wiring harness
As well as obviously the alternator. Tach also if you have it.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
