wiper wiring problem
Old Aug 10, 2012 | 12:55 PM
sportcoupe-z28's Avatar
Car: 82 Camaro SC
so i just swapped a z28 tilt steering column into my sport coupe. the sport coupe didnt have a tilt wheel so i put one in.
the non-tilt column that came out had a delay setting for the wipers. the tilt column just has "high, and low" settings.
my wipers dont currently work, on the tilt column, the plug that comes from the column and hooks up to the wiring harness is slightly different due to the wiring harness being made for the delay.
how do i get around this without changing the entire wiring harness? i need wipers and i dont want to sacrifice the tilt wheel.
Any advice welcome!
Old Aug 13, 2012 | 09:42 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: wiper wiring problem
Find the wiring diagrams and get a pinout of each vehicles steering column connections. Then unpin the old connector and unpin one wire at a time from the current wrong connector and repin it into this connector so that they will match.
Another option if that is the only wiring difference is to swap out that switch assembly for the delay.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 17, 2015 02:52 PM
slade5612
Aug 11, 2015 07:19 PM
