Engine swap advice?
Old Aug 17, 2012 | 02:03 AM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Engine swap advice?
Hey everyone, i currently have a 1991 Camaro RS, it has a 305 carbed engine, stock trans, and its starting to loose its power, as the enging is the original that came with the car.
the car was owned by a guy that swapped the fuel injection with a carb, so the computer isnt there and the harness is all messed up.
I was planning on getting an LS1, but i think it would be cheaper for a 350 carbed. I don't know much about the LS1, so i have a couple questions.
1. Can LS1s be carbed?
2. How would an LS1 compare to a 350? (was planning on adding a supercharger to the 350)
Any advice would be appreciated.
Old Aug 17, 2012 | 02:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine swap advice?
Originally Posted by Jk_Under
1. Can LS1s be carbed?.
Sure
http://www.summitracing.com/parts/EDL-71187/
but you need a electronic controller for the Ignition
http://www.jegs.com/i/Edelbrock/350/...d=#moreDetails
More Hp stock ( and easier to make Hp on ) than 350 but swap costs need to be accounted for
https://www.thirdgen.org/forums/ltx-...ice-lists.html
https://www.thirdgen.org/forums/ltx-...1-instead.html
5.3 truck motors are cheap and popular swaps into 3rd Gen's
Check out
https://www.thirdgen.org/forums/sear...archid=5310041
Old Aug 17, 2012 | 07:51 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
IMO the 5.3 is another wonderful motor from GM. Hence the popularity.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
