84 berli into 85 s/c
Old Aug 29, 2012 | 10:22 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I got a 84 berli that has digital gauges.the engine is long gone but was a 305 w/4bbl. I'm hoping there is nohing special about the engine wire harness that would keep me from useing it to put a carbed 305 or 350 into my 85 sports coupe.the 85 i a factory 2.8mpfi.I'm not going to use the digital gauges from the 84.so I will have to find a harness to get that stuff to work.But in the engine compartment,will the stock harness work just like a 305 harness out of any other carbed engine?I do have the a/c compressor and power steiring pump.I even got the stock carb.PO scraped the engine and tran for quick cash.any how,it has some rust issues that make it a good doner.Also,If I switch fuel tanks and use a carbed v8 is there any reson I would need fuel return lines?You know machanical pump type engine.little info before I start would be great.thanks.
Old Aug 30, 2012 | 09:40 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 84 berli into 85 s/c
Darn,nobody even knows anything about the engine set ups on the berlineta's?Maybe I should have asked in the electrical section.If I dont get anything here by tomorrow I will try there.Keep checking around.
87350gtanj
Aug 8, 2015 10:32 AM
87transam5.7tpi
Jan 2, 2003 08:22 PM
zedder 1 9 9 0
Sep 25, 2002 02:30 PM
gonzo350
Apr 14, 2002 09:46 AM
Forced_GTA
Jun 9, 2001 10:49 AM
