People with Dart SHP block. I have a question?
Old Sep 1, 2012 | 10:39 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I have a Dart SHP SBC. I am currently putting the cam retainer plate on. But the bolts are to large. According to my research, these are the correct bolts: http://www.summitracing.com/parts/NAL-14093637/
Did any of you guys run into the same problem?
Old Sep 1, 2012 | 10:58 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: People with Dart SHP block. I have a question?
check with Dart. i have seen a few small things that differ from GM and dart.
on small bolt size. it's not a biggy. just dont use cheepy bolts always use grade 8.
the plate will hold with 10x32.. but i would want bigger my self..
what size fits now?
Old Sep 3, 2012 | 11:09 AM
Car: 1988 IROC-Z
Engine: 427 SBC
I've tried a ton of bolts with no luck. Either to big or small. I don't know if maybe it needs to be re-tapped? I'm awaiting an email from Dart.
Old Sep 7, 2012 | 07:19 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Update for anyone who might search with the same problem. The correct bolt size is 1/4-20 in. I had to re-tap the holes.
Old Sep 7, 2012 | 07:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I honestly do not remember what i used. I thought i used the bolts from my old block but maybe thats not the case? There are 2 different plates as you know but i think the bolts were the same. I just cant remember what i used! For some reason tho 1/4-20 sounds right i may have done that but didnt have to tap my block. I really think i just reused my stock 89 bolts which had the star torx bit head i believe.
Old Sep 7, 2012 | 07:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"I just cant remember what i used!"
I can't either. So there must have been no drama to it.
Old Sep 7, 2012 | 08:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats true. Usually the big drama stuff i dont forget!
Old Sep 7, 2012 | 09:30 PM
Car: 1989 GTA
Engine: 369 TPI
There were two areas that I had to deal with. One was the oil pressure pressure port above the oil filter is different on the Dart SHP block then the factory L98 block. I had to do some finagling to fit in the oil pressure sensor so that it cleared my headers.
The other had to do with my AFR rev kit. The cylinder walls are bigger on the SHP block and they come further into the valley area. So we had to do some machining on the AFR rev kit in order to get it to fit. Other than that I can't remember anything else that was out of the ordinary.
Old Sep 7, 2012 | 10:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Wow my block my oil pressure port was fine and the stock one worked well. Wonder if these blocks changed over the years?
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
BBSDesigns
Aug 11, 2015 07:39 PM
