Static timing
Old Sep 15, 2012 | 04:51 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Static timing
I'm swapping out the lame 305 TBI in my 91 RS with a 330hp Vortec 350. I am keeping the TBI and have upgraded to an EBL. Should I set the static timing at 0 or try a couple degrees? I've read to advance the timing but can't figure out if I should do the static or adj it in the EBL? Let me know what you've done and how it worked.
Old Sep 18, 2012 | 06:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you mean "static" as in setting the distributor in the hole before firing it up, or the base timing with the engine running and EST wire disconnected using a timing light?
Old Sep 22, 2012 | 02:35 PM
gregl316's Avatar
Re: Static timing
I am sorry for the confusion. Yes I mean when I first start up the car and set the timing to 0 with out the computer hooked up. Static timing no advance. I have read to set it at 2 maybe even higher I just don't know when they were referring to. Or should I even play with this at all the computer takes care of it all.
I am installing a Vortec 330hp 350 in my 91 RS in place of the 305. I am keeping the TBI but am going with all performance parts. I have done the research for the swap so all the nessory stuff has been swapped. I am going with an EBL system I bought from and so far are very happy with from Rbob. He has been very pashionte with me even though I have asked some real stupid questions and I have plenty more.
Old Sep 27, 2012 | 06:27 AM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Static timing
what should the timing advance be set to when installing the distributor?
thats static timing right?
Andrew6.688
Dec 13, 2015 10:59 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
