305TPI to 350 TPI swap - Engine choices
Old Sep 25, 2012 | 08:14 PM
OldAndInTheWay's Avatar
Car: '78 Pont T/A, '87 IROC
I've read through a lot of the posts regarding engine swaps. Got a lot of great advice on here. I still have a few questions, mainly about what engine to buy.
I have a 1987 IROC with a 305 TPI. The engine is kaput. I'd like to keep the TPI and get a 350, long block I guess. The car will be a "for fun" car. Not driven daily, doesn't have to be super fast just respectable. I have other cars so it being out of commision for awhile is ok. I won't be doing the work myself, my mechanic will. I'd like to spend under $2500 for the motor (not inlcuding installation) but would consider spending more if it makes sense.
Can just about any 350 be used for this purpose or does it need to be one specific to a TPI setup?
This one has been recommended by a few people
http://www.rebuilt-auto-engines.com/...43112154432.26
are there other choices that I should be considering?
Also i believe the following needs to be done: replace 19lb injectors with 22lb, new knock sensor, 350 PROM or have mine re-done, new ESC Module.
Am I leaving anything out?
Thanks in advance for any help.
Rob
Old Sep 25, 2012 | 08:52 PM
Re: 305TPI to 350 TPI swap - Engine choices
A few other things. The car is stock and its an automatic. In case that matters
Old Sep 25, 2012 | 10:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by OldAndInTheWay
Can just about any 350 be used for this purpose ?
Basically
but given the limitations of the TPI intake ( does not rev high) you want a camshaft suited to bottom end / mid range running
vs all out top end.
Old Sep 27, 2012 | 08:18 AM
Ok, thanks for the info. I'll keep that in mind when getting the engine.
Old Sep 27, 2012 | 09:34 AM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Watch out for the later vortec motors, the heads are better, but the intake its vortec specific. So you'll need to get the baseplate for those heads.
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
