Really need accurate information....
Old Sep 22, 2012 | 10:29 PM
Crudsturbo's Avatar
Okay I have a 1985 Z28 305 TPI whole car. Also have a 1991 305 Iroc motor, trans, rear, entire harness minus wires that were in the dash. But do have entire harness and ecm from that side.
Need to know what I need to do to swap this into the 85. ECM is bad in the 85, motor smokes a bit, trans is shot, so swap is happening. ECM is only like 55 bucks but if I can use the 91 free is better.
And when I say harness behind dash I mean like to heater controls, cluster, etc they didnt match whatsoever so I didnt see the point in getting them.
Old Sep 24, 2012 | 07:06 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Really need accurate information....
If you only have the 91 engine harness, you'll need to make a number of changes to the wiring harness to make it plug into the 85, the wiring changed significantly in 90, though it will be worth the changes.
ULTM8Z
Oct 2, 2015 01:25 PM
WhteRbt
Sep 21, 2015 09:48 AM
rb85TA
26
Sep 14, 2015 10:29 PM
86IROC112
Sep 11, 2015 04:04 PM
andy74
Sep 3, 2015 08:41 AM
