engine hits the steering shaft
Old Sep 19, 2012 | 11:03 PM
huntj's Avatar
i am trying to help a friend. he is putting a 350 into a 92 that had a v6. it seems the k bar or the steering control arm might be different. the steering column has two u jointed shaft. slide engine back too far and the mounts hit. too far forward and the headers hit the steering shaft.
so my question. is there a conversion for the steering shaft? is he trying the wrong mounts. is the k member different for for a 350?
ps i did read other forums where it says there are two sets of mounting bolt holes for the different positions( v6 or 350).
has anyone else had this problem.
additional info. i was able to look at the car for a min but had to leave town. he has the mounts from the car he pulled it out of.
Old Sep 19, 2012 | 11:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: engine hits the steering shaft
The steering box and shaft position are the same on all third gens.
Old Sep 20, 2012 | 12:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What did he get the engine out of?
Old Sep 20, 2012 | 06:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Probably trying to use mounts and exhaust manifolds that aren't from another V8 third-gen. That won't work.
Old Sep 22, 2012 | 09:19 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
did he put v8 motor mounts on the k member and put them on the correct spot?
Old Sep 22, 2012 | 09:22 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
If he does that it will slip right on in there.
Old Sep 22, 2012 | 09:34 AM
Engine: L31 350
should as i think the block side of the mounts are the same for most 350s.
Old Sep 25, 2012 | 04:45 PM
five7kid's Avatar
If you haven't already, take a look at the V6 to V8 swap sticky in the top section of this forum. There's a pic of the location of the motor mounts in the V8 position.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MENINBLK
Aug 5, 2015 11:58 PM
