flywheel help
Car: '91 firebird
Engine: 350 4bbl
Transmission: t56 6 speed manual
Axle/Gears: limited slip, 3.73 gears
flywheel help
hi, i have a 91 firebird and i'm replacing the tired out 305tbi that was in it with a '72 chevy 350 4 bolt main. i had previously done a t56 swap. i have the old engine out and was starting to put the clutch stuff on the new engine but the flywheel doesnt fit on. my question is can i just get any ol flywheel that'll fit the 350 or do i need a special one to work with the t56 trans? any help would be appreciated
Car: '91 firebird
Engine: 350 4bbl
Re: flywheel help
i would also like to mention something else. where the flywheel bolts to the crank on the 305 is just a regular evenly round flange but on the 350 there is a counter weight
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: flywheel help
Because the balance arrangement was changed the crank bolt patterns where changed to prevent people installing the wrong balance flywheel / flexplate
Need to buy a flywheel to suit a 2 pce crank SBC
Re: flywheel help
The flywheel you need is the one for 83-85 V8 F-body. You'll find there are 2; one is for the low-perf LG4 sedan motor and is about 22 lbs (basically the same as the one for the extremely low-perf L03 you pulled out), the other is for the high-perf L69 and is about 16 lbs.
If you haven't changed the rear gear, you'll probably want the heavier one.
Car: '91 firebird
Engine: 350 4bbl
Re: flywheel help
Re: flywheel help
No maybe not, depending on what T-56 it is; sorry, I missed that.
If it's a LS1 one, it will. If it's a LT1 one, you'll need a "special" "conversion" one such as the Centerforce 700107.
Car: '91 firebird
Engine: 350 4bbl
Re: flywheel help
ya, its a lt1 one out of a 94 camaro. thats what my main concern was with this question. ok so i guess i'll look up the special conversion ones. hope its not too much
Re: flywheel help
Too much what?
It's kinda heavy... around 24 lbs if memory serves. Might be too much but prolly not, it'll be totally fine for you.
Car: '91 firebird
Engine: 350 4bbl
Re: flywheel help
um no i was actually talking about price which it kinda is but i guess i dont have much of a choice though do i
Re: flywheel help
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
