Seeking distributor knowledge
Old Sep 23, 2012 | 04:43 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
Got a 91 RS, swapped out the 305 with a 355 from a chevy full size pickup. Gone through thoroughly, wiring is good after putting the new motor in.I do have gauge issues I had before the swap but I don't believe it would cause the motor to do what it is doing. It fires very rough, computer picks it up and smooths everything out but then the service engine light comes on. The motor runs for 10-15 min. then dies. Gets to a certain temp and dies. I plan on putting manual gauges in cause most of the instrument panel gauges don't work anymore. I've upgraded the computer chip to match the motor, from TBI chips.com. I've followed the list of needed things for a swap from this website, been talking to people and they have mentioned something about a piece inside a distributor that needs to be changed. How much truth is there in that? I'm hoping to get this thing going someday soon, been working on it, on and off for about 3 years. Thanks.
Old Sep 23, 2012 | 09:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Seeking distributor knowledge
Originally Posted by birdman_29
Gets to a certain temp and dies. the service engine light comes on
Not so much " needs" to be changed but the ICM (ignition control module) inside the dist may be tired and failing when it heats up
Very common problem with old age
Read
http://easyautodiagnostics.com/gm_ic...n_module_1.php
for how to test all your spark system
Old Sep 23, 2012 | 09:22 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
The fact that the CEL is coming on and you have new problems with gauges that aren't working sounds to me like you didn't hook everything up correctly after you swapped motors. Then once the car warms up and the ECM goes into closed loop it dies because some sensor is not plugged in or damaged. You might want to double check your harness connections again and pull the codes to see what the ECM is complaining about.
Old Sep 24, 2012 | 04:04 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
Thanks, the gauge problems were not new, had them before the swap. The 305 seemed to run fine. I keep getting the feeling that the problem is right at the end of my finger tips but just can't get it. Many times I've been wanting to just convert it all to Carb.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Damon
Sep 26, 2015 04:29 PM
