90 camaro rs 305 vortec swap
Old Nov 2, 2012 | 07:08 PM
stolen hot rod's Avatar
90 camaro vortec 305 swap to crate 350 non vortec. what do i need to properly complete this swap. i know all need a non vortec tbi intake but is that all i will need. and can i delete all my smog equipment as well if it has sensors on it and what not. like my smog pump and plug my air injection ports on my manifolds with 1/4'' plugs. crate engine already has installed matching belt kit. idk what happened to my vortec 305 drove it to work today ran great no check engine lights. left it sitting for 8 hours and i come out to what i thought was a dead battery but i tried jumping it for 30 minutes with a f550 ford diesel with heavy duty jumper cables and the engine acts locked up. plenty of oil and radiator fluid. new map sensor plugs. also i installed a new exhaust system yesterday. could i of messed up something by welding on it and not unhooking the ground. i unplugged the positive wire. idk what i did or what happened but im confused and ticked off. any help is greatly appreciated. thank you and god bless.
Old Nov 2, 2012 | 11:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 90 camaro rs 305 vortec swap
Depends what " non " Vortec 350 you are using ; the flexplate / flywheel may be different
You need one that fits the new engine
and can i delete all my smog equipment as well if it has sensors on it and what not. like my smog pump and plug my air injection ports .
Yes
There are no sensors on the AIR system
Old Nov 3, 2012 | 09:42 AM
Ok are they interchangeable
Old Nov 3, 2012 | 10:37 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Both are SBC 's ; the engines basically interchange.
But there are generational ( year to year ) changes that may make your new engine not work in your car without mods .
Some early heads don't have all the bolt holes needed to mount your late brackets , flywheels differ as noted , etc
No biggy , but things you need to be aware of if expecting a bolt in and drive off engine swap
Also if keeping EFI ; you need a 350 prom for the computer, a 350 knock sensor and 350 injectors to replace the 305 specific items
Old Nov 4, 2012 | 08:15 PM
My 305 injectors wouldn't keep. Up with the fuel my 350 needs??
Old Nov 5, 2012 | 01:42 PM
What is a 350 prom and knock sensor and could I got a junkyard and pull a intake and those other parts I need
84z96L31vortec
Aug 20, 2017 12:16 AM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
