Engine and Transmission swap on a 86 IROC z camaro
Old Nov 26, 2012 | 05:22 PM
devinj2233's Avatar
Car: 1986 iroc z camaro
Engine: 383 stroker
Transmission: T56 6 speed
Hi I have a 86 iroc z camaro with a 305 and a 5 speed manual transmission. I am taking the motor and tranny out and putting in a 383 stroker with a 4 speed saginaw tranny out of a 69 camaro. My problem is the bell housing on the 4 speed saginaw is set up for a manual clutch and my car is set up for a hydrualic clutch. The bellhousing doesnt have a mounting bracket for the slave cylinder. if ibuy a bellhousing for a mid 90s z28 with the 350 will my hydraulic clutch set up have enough power to work the clutch on the 383?
My only other option is to convert my car to a manual clutch system and use the bellhousing I have. How hard is it to convert it?
Old Nov 28, 2012 | 04:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would suggest you consider an f-body LT1 T56.
Is the 383 going to be one-piece RMS and internally balanced? If so, everything from the LT1 will fit. If 2-piece or external balance, you'll need a special flywheel.
Old Dec 2, 2012 | 04:02 PM
devinj2233's Avatar
Engine: 383 stroker
Re: Engine and Transmission swap on a 86 IROC z camaro
its a 2 piece so i have to get the special flywheel. Where is a good place to get the conversion flywheel?
Old Dec 2, 2012 | 04:04 PM
devinj2233's Avatar
Engine: 383 stroker
also if i get the flywheel will my 5 speed work in the car or will i have to get a 6 speed?
Old Dec 2, 2012 | 05:50 PM
five7kid's Avatar
If you go with the T5, you'll need an externally-balanced 153-tooth flywheel.
If you go with the T56, you'll need an externally-balanced 153-tooth flywheel. I wouldn't call myself an expert on them, but I believe they are different flywheels.
Look on summitracing.com, search on drivetrain, flywheels, etc., selecting the appropriate choices as you go. For instance, doing this gets you this for the T56 option: http://www.summitracing.com/parts/mc...make/chevrolet
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
milk
Aug 10, 2015 06:26 PM
