Differences between 305 and 350 engines
Old Dec 28, 2012 | 08:32 PM
al1989's Avatar
Engine: 305 5.0 L
Hi I have a 1989 Camaro RS that I purchase a year ago. My question I believe the engine s a 350 How can I till the diffrent between the two engine 305 and 350?
Old Dec 28, 2012 | 08:58 PM
vjgillespie's Avatar
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
re: Differences between 305 and 350 engines
They should say 5.0 or 5.7 in the back along the top of the bellhousing. If I remember correctly the 305 has a small diameter balancer that is close to 3 inches thick. A 350 balancer is larger in diameter and only about 2 inches thick. Someone correct me if I'm wrong about the balancers. Its been a while since I've had either one and I've had alot of 400's in that mix, lol. Good Luck
Old Dec 28, 2012 | 09:11 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
The block casting number also...
Old Dec 28, 2012 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Easiest way is the block casting number. Since the 305 and 350 have completely different bore diameters, they won't share the same casting. Visually looking at the engine, they look the same. If you're lucky, you can find a 5.0L or 5.7L cast into the block.
Old Dec 29, 2012 | 09:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The last three digits of the casting number, which are sufficient to identify the casting, are usually cast into the side of the block in large numbers. Often easier to see than those on the back of the engine.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
