price on engine rebuild 305 5.0
Old Jan 6, 2013 | 11:47 AM
Richgta's Avatar
this guy claims he will rebuild my 305 and bore it for 600 seems like a scam isn't that a little cheap please give me an idea what to expect
Old Jan 6, 2013 | 12:28 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Re: price on engine rebuild 305 5.0
It's around 20 bucks a cylinder to bore. Came bearings cost around 30 to install. Depending on parts used/needed/brand will greatly vary your cost. Could be possible but you may just get basic minimal repairs. What does his quote show for parts?
Old Jan 6, 2013 | 06:40 PM
You can get just about the absolute cheeeeeeeeeeeeeepest dirtiest most garbage possible rebuild on a SBC for that.
It will not be "performance", there will be no attention to detail, it will be mass-produced, it will use the cheeeeeeepest of the cheeeeeeeeeeeeeeeep for every part, it will NOT fix the problems old cars usually have (poor gas mileage, smoke at startup, leaks, etc.), it will disappoint.
First mistake is "rebuilding" a 305 short block AT ALL. It costs MORE to rebuild a 305 than a 350; meaning, if you were to go to yer local buzzard and put him off his carrion long enough to find a 350 carcass, the cost of THAT PLUS REBUILDING IT would almost certainly be LESS THAN "rebuilding" a 305. DON'T REBUILD A 305 short block.
But the first thing we should talk about is, why do you think your short block needs to be "rebuilt", in the first place?
Old Jan 7, 2013 | 11:01 PM
Richgta's Avatar
it has a pretty substantial oil leak and if I got to get that fixed I figured I might as well do a little modification while its apart
Old Jan 8, 2013 | 06:13 AM
Where's the leak?
colton_carlson
Mar 8, 2019 12:21 PM
italiano67
Dec 11, 2016 09:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
