400 sbc with factory TPI: possible?
Old Jan 24, 2013 | 09:55 AM
Soon2beBad91Z28's Avatar
So i have a 400 sbc and I was wondering if it was possible to make good power by using the factory TPI in my 91 camaro? The engine will be bored .30 over, has a crank that is -.20 under, and i will be using a set of heads off an old Chevelle 350. Those heads flow 1.94 i believe, and I already know that I have to drill holes in the heads for the steam holes. With increased compression from the heads, what Cam would work best for this set-up? I know i will have to get bigger injectors and a computer tune.
Thanks for any input!
Old Jan 24, 2013 | 06:26 PM
Re: 400 sbc with factory TPI: possible?
No it is not possible to make "good" power. TPI, being the severe limit that it is to even a 305's performance potential, will totally choke a 400.
Don't bother with those old heads unless they're one of the better castings. Not many were. Post the casting # and we can tell you right away whether you have 160 HP door stops, or potentially 300 HP runners.
I would STRONGLY advise against putting TPI on a 400, even though it will bolt right up and "work". Remember, just because a thing "can be" done, doesn't automatically make it "A Good Idea" to do it.
Old Jan 24, 2013 | 06:28 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Hsr, miniram or superram would be the way to go.
Old Jan 24, 2013 | 06:34 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
The TPI is a torque monster because of the runner length, The base fact that the TPI falls flat on it's face at Higher RPM's isn't good. And then you want to run 350 heads which are more air restrictive probably like 185 CFM maybe at best with I think 65CC heads.. *I think that is wrong and possible lower* Someone step in with the exact numbers.. I think you would be wasting your time and be unhappy with the final result.
Old Jan 24, 2013 | 06:54 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Bad idea. TPI already falls flat after 4500 on 305/350 motors. If you want TPI on that big of a motor, go FIRST or as mentioned above, HSR, MR, or SR. Or, go single plane EFI.
Hotrodboba400
Dec 10, 2019 07:07 PM
Loudnproud86
Jul 14, 2016 12:59 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
