Decided to do a bbc swap into '86 Camaro
Old Feb 12, 2013 | 09:26 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I will finally do it. This car will be a weekend warrior with some racing at our 1/4 track. I just ordered me some hooker swap headers! This big block is coming out of a 74 corvette.
Old Feb 13, 2013 | 12:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cool. What are you doing to the engine? What are you doing for transmission/rear end?
Old Feb 13, 2013 | 04:34 PM
Car: 86 z28
Re: Decided to do a bbc swap into '86 Camaro
For right now I am installing it as is and the rear and transmission should be find.
Old Feb 13, 2013 | 05:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Famous last words
Old Feb 13, 2013 | 05:41 PM
Car: 86 z28
Originally Posted by AlkyIROC
Famous last words
Lol . I've got a 12 bolt with 3.90 gears and the trans has been rebuilt by a reputable shop locally.
Old Feb 13, 2013 | 06:46 PM
five7kid's Avatar
Less power than a stock LS1. So, they'll probably be fine...
Old Feb 13, 2013 | 08:29 PM
Car: 86 z28
Yep less power than Ls1
Don't mind the valve covers.
Old Feb 13, 2013 | 11:49 PM
five7kid's Avatar
Very funny
Old Feb 14, 2013 | 05:37 AM
Maroluver666's Avatar
Car: 89 camaro convertible Iroc
Engine: Chevy 305 sbc
Transmission: Automatic
Axle/Gears: Stock gears no posi
What rockers are you using
Old Feb 14, 2013 | 03:42 PM
Car: 86 z28
Not sure I think they are trick flows . The lifters I know are scorpion.
Old Feb 16, 2013 | 10:49 AM
Car: 86 z28
I received my hooker swap headers yesterday and noticed that they are different from the first 2226hkr I had purchased about 5 years ago . Went back to the jegs website and it says they have been improved and redesigned . We shall see if they are a better fit than the old header design .
Old Feb 16, 2013 | 11:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Keep us informed. Maybe they finally listened to the consumers about how bad the design was. For how much they cost, they better fit better.
They're still only a street header. With 1-7/8" primaries and 3" collectors, they're going to be restrictive for high rpm or large cubic inches.
Old Feb 16, 2013 | 11:37 AM
Car: 86 z28
I will report back with the fitment. I'm hoping they don't turn out to be to restrictive for my 498, I should not need to go much above 6k rpms . I'm going down in primary size as the ones for the corvette are 2" primaries and the same size collector.
Old Feb 18, 2013 | 08:08 PM
Car: 86 z28
Drove the '74 vette for last time , atleast for a while. Started taking the engine out to put into the Camaro.
Old Feb 19, 2013 | 05:13 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I almost went BBC but built a 406 instead. I got a 454 block 2 sets of rect port heads and a ls6 steel crank. I also got a 4l80e and a ford 9 but still havent got the 4l80e installed yet. A BBC is still very competative even with the mighty LS series of engines out there. You can get over 800 cubic inches and they still make and develope heads for the old mark IV that way out flow any LS head.
Old Feb 20, 2013 | 11:15 PM
Car: 86 z28
It's almost completely in .
Old Feb 21, 2013 | 08:29 AM
Blade09's Avatar
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
My only question, and a little off topic, is why take a stingray off the road and build a third gen. I mean I love my car but I'd love to have a vette to drive as well.
Old Feb 21, 2013 | 09:41 AM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
man you have some pretty cool cars in your sig. i too wondered why the 74 vette was loosing its engine to a camaro, but im guessing you have "better" plans for the vette
Old Feb 21, 2013 | 10:05 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Look for some Ed Quay headers. They fit great. I sold mine on here a few years ago when the 440 (.060" over 427) came out of mine. Those hookers are a restricition on anything other than a stock bbc or a 396 imo.
Old Feb 23, 2013 | 12:06 AM
Car: 86 z28
I plan to put a Lsx engine in the vette later on. Also the camaro is better suited for drag racing which is what this big block was built for. I plan to dyno tune the camaro and see how much it puts down with the swap headers.
Old Feb 24, 2013 | 04:01 PM
Car: 86 z28
Very funny
Thanks!
Old Feb 25, 2013 | 08:41 PM
Car: 86 z28
Some crappy phone pics , will try and get some real pics later on.
Old Mar 4, 2013 | 05:13 PM
Car: 86 z28
Almost to the point of starting the engine.
Hopefully I can get it running good again. This vid is when I had a solid roller w/a 680ish lift
Old Mar 16, 2013 | 12:42 PM
Car: 86 z28
A little update , the motor and tranny are in. A note for anyone doing a 12 bolt swap , the conversion u joint part#for a stock driveshaft and yoke for a 700r4 and a chevelle 12 bolt is neapco or duralst gold # 3-3130 .
Old Mar 26, 2013 | 11:22 PM
Car: 86 z28
A sound clip of the motor running ( it's actually a phone video but the quality sucks) . The cam sounds tamed considering it's a 650ish lift hyd. roller . It's got a 4-7 swap comp. cam. I couldn't really hear any difference in exhaust note. http://s870.photobucket.com/user/big...dfdda.mp4.html
Old Mar 28, 2013 | 12:02 AM
Car: 86 z28
A pic with the C5 corvette wheels. Name:  IMG_20130327_223758_zpsae9cd9d8.jpg
Old Mar 28, 2013 | 03:38 AM
brando54009's Avatar
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
big motors sticking out of the hood are way cooler than regular looking ls sitting nicely in the engine bay imo.
im looking at dumping a big block in my car as well and i was wondering how satisfied you are with those headers? is it worth the price?
Old Mar 28, 2013 | 05:41 PM
Car: 86 z28
At this point I am satisfied especially how easy they went on (with the redesign) . I may change my opinion when I dyno it and I am in down in power.
Old Mar 28, 2013 | 08:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Throw on a tunnel ram and it looks even more impressive. A roots blower would just scream HP. Yes, there is a tunnel ram on my engine. The engine sits lower than stock so it doesn't poke through the hood as much. I used to have an aeroscoop over the toilets but the Hilborn style scoop looks so much better.
Old Apr 10, 2013 | 01:33 PM
Car: 86 z28
The camaro is up and running. Now moving on to paint, hopefully I do a good job at it. As you can see it needs it.
Old Apr 10, 2013 | 07:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Paint is only for show. It does nothing for performance. If you make it look like it should go fast, it better go fast.
Old Apr 10, 2013 | 08:12 PM
Car: 86 z28
I hear you, I just don't like all the clear coat peeling off. I'm not going crazy on the paint job.
Old Apr 13, 2013 | 09:01 PM
Car: 86 z28
I've got my power steering running now. It was a chore to turn without it on the street and having a spool .
http://s870.photobucket.com/user/big...3698e.mp4.html
Old Apr 17, 2013 | 01:20 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
How are they different from the original ones?
Old Apr 17, 2013 | 12:16 PM
Car: 86 z28
One of the biggest difference is the removable primary tube on cyl# 2 on the early design ,it's so longer removable and the bend is very different.
Old Apr 18, 2013 | 04:24 PM
FastCamaro383's Avatar
Car: 1992 Pontiac Firebird Formula
Engine: 383
Transmission: TH-350
Did you have to change the motor mounts?
Old Apr 18, 2013 | 05:08 PM
five7kid's Avatar
Admittedly off-topic and non-tech, but curious if you are in western Texas, or in West, Texas.
Old Apr 18, 2013 | 05:44 PM
ghost91's Avatar
Car: 1991 Camaro Z28
I was wondering the same thing to see if he was ok or not... Shame of what happened..thoughts with everyone in Texas. Hopefully he's ok
Old Apr 18, 2013 | 09:48 PM
Car: 86 z28
I'm in western Texas , sorry will go back to correct that. It's a sad situation what happened there. Our thoughts and prayers are with that community.
Old Jun 23, 2013 | 01:07 PM
Car: 86 z28
The swap is done . It's looking a little bit better now.
Old Jun 23, 2013 | 05:15 PM
ghost91's Avatar
Nice! More pics please!
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
reiderz iroc
Aug 13, 2015 04:57 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
