89 lb9 to l98 cam question
Old Feb 28, 2013 | 07:11 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
Hello all.
I have an 89 formula with the lb9, 5speed, 3.45 bw axle, g92, n10 dual cats etc. with a hurt motor.
I have sourced a low mileage l98 from a gta and would like to slip that in (easy) but i would like to pop in a cam as aggressive as the stock lb9 cam is on the 305.
I know the t5 g92 n10 lb9 cars had a relatively aggressive cam for the time, but i do not know its specifics. I have read that is is similar to the l98 cam so in theory an lt4 hot cam might be similar in an l98?
I would like to leave the l98 cosmetically stock but am open to internal upgrades if need be, ie rockers, springs etc.
Any ideas?
Thanks!
Old Mar 3, 2013 | 01:33 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 89 lb9 to l98 cam question
An LT4 is much different/bigger than any of the L98's. Myself, I'd try to find an L98 out of a Y body, as they were the "hottest", and call it done. We know that's good for 30 HP. I'm guessing much more than that and the heads start to be the bottleneck.
Old Mar 6, 2013 | 09:59 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You don't want the Lt4 hot cam. You will need lots of tuning to make that work and the lift is too high for the stock springs anyway.
lt500r55
Sep 1, 2021 01:30 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
anesthes
Aug 8, 2015 09:37 PM
