Junkyard 89 IROC build
Old 03-25-2013, 07:19 PM
  #101
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Junkyard 89 IROC build
a funny guy
Old 03-25-2013, 09:05 PM
  #102
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Originally Posted by tunedperformanc
a funny guy
Worth a shot.
Old 03-27-2013, 06:02 PM
  #103
jas2730's Avatar
Almost finished porting the Stealth Ram. I'll have it finished up tomorrow. Here's a pic.
Old 03-27-2013, 06:04 PM
  #104
Engine: Lb9
Transmission: M20
Ok, send it to me for a quality inspection lol
Old 03-27-2013, 06:11 PM
  #105
jas2730's Avatar
Right after I receive that intake your donating to me i'll send this one out.
Old 03-27-2013, 06:23 PM
  #106
Engine: Lb9
Transmission: M20
Dammit I was so close
Old 03-27-2013, 06:28 PM
  #107
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
here is the pic of mine i told you i would post cut 1.5 coils mine SHOULD be lighter.
No a/c equiptment at all, no crash supports front or rear, no rear seats no accesories only alternator mounted down low and thats it you may wanna do only 1 coil
Old 03-27-2013, 06:31 PM
  #108
jas2730's Avatar
I'm not seeing a picture.
Old 03-27-2013, 06:38 PM
  #109
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Nice build so far!! I love the color of that iroc and the story of saving it from a jy. Cant beat that!
As for your front springs...are you sure you clocked them correctly or that they were clocked correctly before you bought it? That would cause the issue your seeing there. If those are stock iroc springs there is def something wrong.
Old 03-27-2013, 06:45 PM
  #110
mr305's Avatar
Car: 91' RS
computer didnt wanna work for some reason its up now tho lol
Old 03-27-2013, 06:46 PM
  #111
jas2730's Avatar
Still has the stock springs on it. Never been removed. It didn't have this stance with the 305 and a set of 90-92 wheels that I was using temporarily.
Old 04-07-2013, 09:17 PM
  #112
jas2730's Avatar
Almost there! Need some vacuum fittings for the plenum and a upper radiator hose.
Old 04-07-2013, 09:20 PM
  #113
Engine: Lb9
Transmission: M20
Sweeeeett
Old 04-07-2013, 09:22 PM
  #114
jas2730's Avatar
Sweeeeett
It will need a good cleaning as well. Got my greasy paw prints all over. lol
Old 04-08-2013, 10:56 AM
  #115
kentuckyKITT's Avatar
Car: 3 T-Tops
Engine: 327/305/305
Transmission: TH350/700R4/700R4
Axle/Gears: 3:42/2:73
Very nice! That is going to be one awesome IROC when it's done!
Old 04-08-2013, 11:04 AM
  #116
jas2730's Avatar
It will still need paint, but I want to enjoy it for spring and summer before I tear it back apart for paint.
Old 04-12-2013, 10:57 AM
  #117
jas2730's Avatar
Well, I tried to fire the car yesterday and I have some major wiring issues. After cranking for a
couple seconds the negative battery cable started smoking and a brake line welded itself to the header. I also have no power to the ecm. I believe both are being caused by poor grounds. I will redo them and see. I just hope I didn't burn anything up.
Old 04-12-2013, 11:27 PM
  #118
Engine: Lb9
Transmission: M20
That's a great way to ruin your day
Old 04-12-2013, 11:41 PM
  #119
jas2730's Avatar
Your telling me! I don't know what I was thinking. I guess I thought after a 10 month engine swap I'd be able to turn the key and everything would go perfect with no issues. Ha! Lol.
Old 04-12-2013, 11:50 PM
  #120
Engine: Lb9
Transmission: M20
Well if it makes you feel any better I hammered that 2011 vert into the ground last night
Old 04-12-2013, 11:56 PM
  #121
jas2730's Avatar
Nice! Did you box those wheels up for me yet?
Old 04-12-2013, 11:58 PM
  #122
Engine: Lb9
Transmission: M20
I'm waiting for the funds to clear first
Old 04-13-2013, 12:11 AM
  #123
jas2730's Avatar
33K. Don't know where to start negotiating!
Old 04-15-2013, 10:27 PM
  #124
jas2730's Avatar
Okay, so I ran my ground cables again. No more smoking or welding. The car cranks much better but I still have no power to the fuel pump. Also when I jumper the fuel pump and try starting it, it backfires fires through the headers but won't start. So more work to do. Any advice on the fuel pump or how to trouble shoot the ecm would be appreciated.
Old 04-15-2013, 11:13 PM
  #125
Engine: Lb9
Transmission: M20
Do you even get a 2 second prime ?
Old 04-15-2013, 11:18 PM
  #126
jas2730's Avatar
No. Won't run without a jumper.
Old 04-16-2013, 07:46 AM
  #127
Engine: Lb9
Transmission: M20
You might try your other cars ecm and memcal to narrow it down. If you put a volt meter or test light on the dark green/ white wire on the relay or a1 of the ecm turn the key on and you will have power for 2 seconds. The relay ground is tied into the grounds behind your passenger side cylinder head. The orange wire to the relay will be hot all the time and goes to the under hood fuse. Bye jumpering to you mean jumping the oil pressure switch ?
The orange to gray or do you mean applying power to g of the aldl ?
Old 04-16-2013, 07:49 AM
  #128
jas2730's Avatar
Applying power to g on the aldl.
Old 04-20-2013, 07:12 PM
  #129
jas2730's Avatar
Finally got my fuel pump figured out. Reset my timing, then blew my starter to pieces!
Old 05-13-2013, 11:51 AM
  #130
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Originally Posted by NathanLewis
I may anger people saying this (impressive work by the way) but what's the purpose of owning more than one thirdgen camaro? I could see myself getting bored restoring one after the next.
The man rescued a straight decent looking IROC from the crusher.. I commend him for doing so. Stone
Old 05-13-2013, 11:53 AM
  #131
jas2730's Avatar
Thanks for that.
Old 05-13-2013, 12:01 PM
  #132
jas2730's Avatar
Progress has slowed again. When I realized the car wasn't going to be ready for Ocean city I decided to tackle a few things on the convertible and take it instead. I'll wrap the 89 up when I return from vacation.
Old 07-09-2013, 07:04 PM
  #133
jas2730's Avatar
I've got to get the idle set but she finally fired!
Old 07-09-2013, 07:16 PM
  #134
Engine: Lb9
Transmission: M20
about time slacker, working on mopars lol. Sounds healthy
Old 07-09-2013, 07:23 PM
  #135
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Nice job! She's gettin' tharrr
Old 07-09-2013, 08:55 PM
  #136
jas2730's Avatar
Yeah, I know. You know how it goes. I got burned out and wanted to play with something new. I've been been in love with the SRT 4 lately and put off for 3 months what only took 3 hours to finish today.
Old 07-09-2013, 09:00 PM
  #137
jas2730's Avatar
Thanks man. It's come along way from way I found it in the junkyard but still has a long way to go. Building an engine and getting it swapped was my biggest obstacle and that one is behind me.
Old 07-09-2013, 09:03 PM
  #138
jas2730's Avatar
Yeah, she sounds pretty mean. I noticed my tach floating, I wasn't twisting my new engine 5 grand on the first startup. lol
Old 07-11-2013, 12:10 PM
  #139
jas2730's Avatar
Got it idling on it's own but it's surging. Don't mind the smoke in the vid. The p.o. must have painted those SLP headers with regular paint because it's bubbling and burning off.
Old 07-11-2013, 03:27 PM
  #140
jas2730's Avatar
Played with the timing a little more and it's not surging so much. Had to buy a new battery charger. Advance had a 200 amp Schumacher for $124.99. Found a promo code for $50 off when you spend $125. I threw a $2 roll of shop towels in my cart to make it $127 and got it for $82 including tax.
Old 07-11-2013, 06:45 PM
  #141
jas2730's Avatar
A little better. Idling a little high now but getting there.
Old 07-18-2013, 06:53 AM
  #142
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
for a junk yard car it looks great from what i have seen of the body i would fix the chin spoiler and call it done it looks great. motor looks great also your doing a great job.
Old 07-18-2013, 10:13 AM
  #143
jas2730's Avatar
Thanks. It has some clear coat peel in a few areas so I'm just going to spray the whole car. The interior needs the most work though.
Old 09-22-2013, 05:10 PM
  #144
art91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 350 5.7 liter
Read your entire thread and wanted to say you've done a great job thus far, keep up the good work and I look forward to seeing more.
Old 09-22-2013, 05:33 PM
  #145
jas2730's Avatar
Thanks. I've been preoccupied with my SRT4 lately but it just rolled out of the garage today after a complete engine swap. So maybe i'll have some time to get back on the IROC.
Old 09-23-2013, 01:53 PM
  #146
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Too much srt time...winter is comin soon man...roast the tires while u can
Old 09-23-2013, 01:57 PM
  #147
jas2730's Avatar
I'm taking the SRT4 to Ocean City next May. Gotta make sure it's right so I can take out those coyote junkstangs. Lol
BlueIroc-Z
06-09-2019 03:22 AM
italiano67
12-11-2016 09:21 AM
jharrison5
08-19-2015 05:53 PM
matthew911
08-12-2015 09:38 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: Junkyard 89 IROC build
