IROC L98 Engine Upgrade or Swap
Old Mar 18, 2013 | 10:01 PM
bambaera's Avatar
Hello all, I have a 1988 IROC with the L98, 700R4, 9 bolt rearend. I'm looking to eventually upgrade the motor and I've boiled it down to two main ideas, which I am flexible on. I'm looking for any advice, suggestions, alternatives, or tips. Although, I am not interested in swapping an LT1/LS1, mainly because I do not want to deal with the new computer. Also, the car is going to remain in California, so I'm screwed when it comes to swapping in a carburetor or removing the emissions equipment.
  1. My first idea is ripping the L98 out, tearing it down to a bare block and taking it to a machine shop. At this point, I would want them to bore/stroke the block, I'm open to any size 383ci or larger. Either I would go with a separate kit for the rotating assembly and give it to them to install or buy the parts from them. This was my first idea because I wanted to retain the original motor to some degree.
  2. Second, I could buy a long/short block, pull the L98 out and transplant the intake manifold, oil pan, Vcs, etc. If I buy a built/complete shortblock of a given size (383, or whatever the next side up is) I would then buy aftermarket heads and matching cam, since the stock L98 stuff wouldn't work well with a larger displacement engine. The analog to this is just buying a built/complete longblock of 383 or bigger; either way I would re-use the stock intake and everything and sell my stock L98 longblock which I imagine would be easier than selling everything piecemeal. This was attractive to me because at the end of the day, I work full time and tearing down the L98 to a bare block is going to take some time.
The big questions I'm still working on are the following:
  1. If I rebuild/stroke and bore the L98, what cubic inch should I try for, what heads and cam?
  2. If I go with a short/long block, what would be the best motor/heads/cam/intake combination?
I hope this establishes my thought process and where I am tryingto go. I am open to suggestions and alternatives as I said, so pleasefeel free to throw them out there! My basic goal is to rebuild themotor or drop a new one in, put out between 350-450hp and retain allemissions equipment to pass California smog inspection. Money is not a huge deal, but it's not unlimited. I would like to stay under $5,000 total. Thanks foryour time in advance!
Nate
Old Mar 20, 2013 | 04:06 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: IROC L98 Engine Upgrade or Swap
Even after market LTR's on a 383 yield a great tow truck motor but little else. I'm a bit disappointed with my build as the torque is great but you leave a lot of HP on the table with a TPI. A stock intake would be even more biased towards torque. Either go to a different intake, (HSR, miniram, etc.), on a stroker or stay with your 350.
Old Mar 20, 2013 | 07:00 AM
Can't use HSR or MiniRam in California. Not emissions legal.
Best route to go out there would be, LS1. (or similar, something from the same series, such as a 6.0L) If for whatever reason that's not attractive to you, best thing to do is "eventually" sell the car with the weak TPI motor and get a newer car. While some of the CA guys claim very impressive power #s for emissions-compliant L98s, they're NOT CHEAP to get there; and require a level of tuning skill, attention to detail, knowledge of electronics, electronic (computer) equipment, etc. that sounds to be beyond your scope.
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 11, 2015 03:17 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
