How easy is it to swap a 305 to 350 in 84 camaro.
Old Mar 31, 2013 | 02:18 PM
Darion321's Avatar
Hey guys. I just found a 84 camaro on craigslist for 2100. It currently has a 305 but i need this car to get to and from work and with how old this engine is i cant depend on it not breaking down. I want to swap it for this 350:
http://www.summitracing.com/parts/na...9/media/images
How easy would it be? Do i need to do any fabrication or anything or can i just take out the other engine and drop this one in and everything will fit correctly? Thanks for the help.
Old Mar 31, 2013 | 02:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How easy is it to swap a 305 to 350 in 84 camaro.
It's a direct swap, the only difference is the dipstick is on the opposite side.
Old Mar 31, 2013 | 02:40 PM
Darion321's Avatar
So how do i fix that? Or is it fine where it's at?
Old Mar 31, 2013 | 02:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You just have to tweak the tube a bit to clear stock manifolds, or use an aftermarket flexible tube. If you're using headers it's not a problem at all.
Old Mar 31, 2013 | 03:17 PM
Darion321's Avatar
And it will work with the tranny already installed?
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Mar 31, 2013 | 03:23 PM
Darion321's Avatar
Also one last question. What other engines are direct swaps with the 84 camaro?
Old Mar 31, 2013 | 03:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For a 305, only another small block chevy.
Old Mar 31, 2013 | 03:29 PM
Darion321's Avatar
So any small block chevy will be a direct swap?
Old Mar 31, 2013 | 03:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes with only very minor issues depending on the year of the new block.
Old Mar 31, 2013 | 04:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
About that engine, per crateenginedepot.com:
Oil Pan / Filter / Adapter / Dipstick:
The 350/290 HP engine block has provisions for both right-hand and left-hand dipsticks. The 350/290 HP engine includes a 4-quart oil pan Part number 10066039 which has the “double bump out” for both dipstick designs. The oil dipstick for the 350/290 HP engine for the right-hand (passenger) side of the block is 10190942 (indicator) and 12552920 (tube). If not using right-hand dipstick, use plug 09421743.
Old Mar 31, 2013 | 04:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would make it a perfectly direct swap, then.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
