PCM problem !! Can it be fixed??
Old Apr 4, 2013 | 09:23 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
well I just bought this set up for 50 bucks ... and noticed that pin 2 on the PCM side was missing ... well it was in the correct connector but on the harness side? is this a big problem?? its the PCM ground .
the red connector .. and I've been trying to upload but it won't let me ...
Old Apr 7, 2013 | 02:07 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: PCM problem !! Can it be fixed??
i was confused what the question was until i looked really hard at the pic.. the pin pulled out of the pcm.. that means the pcm is junk- get another one.
Old Apr 7, 2013 | 03:29 AM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Yeah I thought the same thing .....I opened the pcm up and the pin was still intact just broke at the bend can it be solder back on to the other half? The rest of the pin is on the circuit board still with no damage
Old Apr 12, 2013 | 09:58 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You can always solder yourself a wire to it and just connect it manually to the harness
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 27, 2015 07:28 AM
NBrehm
Aug 25, 2015 11:49 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
