Engine Sensors
Old Apr 6, 2013 | 12:38 AM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Engine Sensors
Where are the engine temperature sensors on the car? And where does it connect to on the engine itself? Pictures would be helpful if anyone has any.
Old Apr 6, 2013 | 12:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Engine Sensors
Depends on what specific engine. Some coolant temp sensors are in the head. I know TBI engines have them in the front crossover of the intake. TPI engines may be different.
Old Apr 6, 2013 | 01:04 PM
Re: Engine Sensors
It's a 305 with a carb. Block numbers said it was a 80-85 motor.
Old Apr 6, 2013 | 01:13 PM
Re: Engine Sensors
The year of the motor doesn't matter.
The gauge sensor is in the driver's side head between the #1 & #3 spark plugs.
The CTS for the computer is in the water outlet.
The fan switch is in the pass side head between the #6 # #8 plugs (same hole as the gauge sender except that the head is turned the other way)
Old Apr 6, 2013 | 01:15 PM
Re: Engine Sensors
Okay thanks.
Old Apr 6, 2013 | 01:27 PM
Re: Engine Sensors
Also what does the hook up look like for it?
Old Apr 6, 2013 | 01:31 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Engine Sensors
Since someone swaped your car to a carb, who knows if those wires are still there.
Go get some sensors form the parts store, then look for plugs that match, the wires may be tucked up somewhere or just hanging down, or chopped off.
One of the reasons I dislike carb swaps.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
