Choosing the right Vortec heads !
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I'm looking at summit, and they offer the GM vortec heads # 12558060 and there own summit brand Vortec heads # 151124 that seem like a better head for less money. but the cc on both heads are a little different...Im wondering if there a difference in power, i e compression or flow, If anyone has experience with these heads please say so, as im trying to pick some good vortec style heads in the next couple of days !
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Choosing the right Vortec heads !
Take your pick, just make sure they are able to handle your cam. Stock vortecs are limited.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If going on a fresh build then the engine can be built to get a desired comp ratio with any size chamber
If going on a stock engine then most likely the larger chamber Summit version will give a lower CR ( less power ) than what you have now
Again depends what engine you currently have; chamber size varies widely across the years
If the GM version has smaller chambers than your current head then it will raise the CR
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Your right, I need to find out what the stock cc are on a 1992 L98 350 iron head is. I'm sure it's around here some where.
Car: 82 Z28
Transmission: T400
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
I don't like the shim style head gaskets.Not much bite in them and you really need to have the deck finish to handle/help seal them long term.
The Vortec engines have a head gasket issue in part because of less head bolts and in part because of the gaskets.I'm not sure if that isn't the reason why we are finding so many cracked used Vortec heads too.
Far and away better to machine parts and have the proper pistons for the proper SCR using a .039 head gasket.
Car: 1971 Camaro
Engine: 427
Gary, I saw a recent Hot Rod story where they said to never use those shim tyope gaskets with the leter model 'lightweight' heads.
I was suprise to read this, the least 2 smallblocks i built, I used the shims, and coated them with a copper spray. Had no issues.
Car: 1971 Camaro
Engine: 427
Car: 1971 Camaro
Engine: 427
The two heads you posted are, 64cc and 67cc. A very minor difference, heck some oe heads may see that much of a variation from chamber to chamber.
Certianly not enough to notice a differecne in power on a mild build.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Strokers increase comp so larger cc is used for lower compression for street pump gas deals. Thats ofcourse you cant find proper pistons to give the ratio you are looking for. Between head size and piston you can dial in what you need.
Other reason to lower... Booost
The edit should read less intake bolts.
I'm going to go back to what I said at first.Why the hell would you invest into anything that has a history of cracking??. Then cut them even more on a thin casting,then use a shim gasket.Just doesn't make much sense.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
so what is the stock compression of a 1992 350 Z ? Does anybody know what the new heads will make it?
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
I thank you for wanting to help Irocz442, But please, Don't post your for sale items on these pages ! Thanks
Car: 82 Z28
Engine: 383 SBC
Axle/Gears: 3.50 9 inch
https://sdparts.com/details/scoggin-...ter/sd8060arpm
I'm not saying its the best option as when I bought this package 8 years ago it was only $900, but just for an idea. Vortecs do require a special intake manifold, just something to consider.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
The EnqineQuest vortecs are very nice. I got mine fully assemled with guide plates and screw in studs for less than 800 new.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Thanks, I bought the summit brand vortec heads, that are good for more lift and i have the correct lower intake, I was just not sure if i needed to lower the com from a 67 to a 64, If that really made much difference..
Car: Iroc-Z
Engine: 383ci
Transmission: 700hp 700r4
Axle/Gears: 3:45
Car: Iroc-Z
Engine: 383ci
Axle/Gears: 3:45
What do you intend to run for an INTAKE manifold gasket?
It depends somewhat on your choice of intake manifold.
I had been running the OEM Vortecs (with an RPM Air Gap inatke) for years with the Fel-Pro MS90131 without any trouble. Now that I've moved up to the RHS Vortec (Pro Torker) ,I've found that engine is uisng a lot of oil and plugs 6 and 8 are oil fouled. A typical intake gasket failure. Now I'm on the look-out to see who has done what.
Here are a few of the choices. Some of the plastic carrier type with silicone beading (which is the 90131 as well as the GM 12529094 and the 1255 which I believe is a Printoseal type of gasket on a composite paper.
Fel-Pro 1255 composite gasket. Printoseal on composite paper
Fel-Pro MS90131. Original edition of this gasket similar to GM 1259094. Plastic/nylon carrier with silicone bead.
Fel-Pro MS908000T. The latest version of the MS90131.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's not installed yet, but on my mock-up, the Fel Pro 1255 seemed to be a good fit with my Edelbrock TPI base. I did a lot of reading and this seemed to be the preferred gasket with aftermarket intakes.
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Wow, Thanks for the info, I hadn't even put much thought into it yet ! But, I guess I better, thanks for the info.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
