Transplanted a vortec crate with ED3817..bypass?
Did a search but came up empty, and the directions on the paper for the TPI Intake were pretty bad. There is a water jacket access on the top of the intake by the distributor, and one on the front of the intake with what appears to be another NPT fitting on the right side with a 1/8th inch hole, down and to the right of the thermostat if looking straight at the engine.
Which gets NPT and jacketed, and where does it get routed to? I drilled a few 1/8th holes in the old stat to test, but its too much water movement and it runs too cool. I know the crossover is to circulate water in just the block, and I want to make this happen. Should I T up the rear jacket on the intake to the front jacket using those two holes?
The transplant was into an 85 Corvette, using the Vette pump and all that.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Transplanted a vortec crate with ED3817..bypass?
I believe the small hole on the front you are talking about is a threaded bolt hole ; not a coolant port
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 82 Z28
Transmission: T400
Are you are talking about the WATER PUMP bypass on Vortec blocks , not the intake?
"Any small block engine, regardless of year, that uses Vortec heads, will require an external coolant bypass line from the intake manifold to the 5/8" hose nipple on the water pump (passenger’s side). Suggested routing is from the 3/8 NPSF boss on intake manifold to the water pump."
Car: 82 Z28
Transmission: T400
On a Vortec block you are SUPPOSED to have a external connection between the intake and the water pump.
Achieved by
1. a hose from the intake side of the pump to the intake manifold as done on the Vortec from the factory
2. a line from the intake to the heater core back to the pump inlet
3.Drilling bypass holes in the stat
FWIW
My 500Hp 383 has a Vortec block with a non Vortec waterpump and a drilled thermostat and it has no cooling problems
Any of the ports on the intake that are before the stat
Achieved by
FWIW
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Achieved by
FWIW
Achieved by
FWIW
Gotcha, now, before I tear back into stuff... the water passing through the throttle body/heater core is/is not a bypass in the TPI system?
Vortec crate, 85 corvette water pump, no heater valve, stock TPI system
RedLeader289
May 28, 2019 01:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
