pulley set up
Re: pulley set up
air pump can be removed without replacement, AC delete pulley can be bought new.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: pulley set up
If its a v6 with the AC on the drivers side, all you need is a different belt. I removed both from mine shortly after I got it, and just bought a new belt at autozone. You have to dig through the options in their site, but they have one that is for a v6 with no air and no smog pump. I can't remember the part number anymore, it's been a few years.
Re: pulley set up
oh, ignore comment then...I don't do V6s
Car: 90 RS
Engine: 305 for now
Axle/Gears: stock 2:73
Re: pulley set up
its a v8 305 tbi now switching to carbed 350 would like t get rid of ac and polution pump that whole bracket if posible
Car: 90 RS
Engine: 305 for now
Re: pulley set up
no, reroute. check the faq, it´s in there
Car: 1992 Camaro RS
Re: pulley set up
I wasn't sure if he had a v6 or a v8. Just thought id mention it in case he did since he didn't specify. Wasn't trying to one-up you or anything.
To the OP- if your going carbed, you can do it one of 3 ways. First is what Twin Turbo described, second is switching to a v-belt setup(cheap but a pain to keep the belts tight), third is to do what I finally did and use a serpentine setup from an early-mid 90's full-size van. You'll need a shorter belt and a long flex radiator hose to reach around the alternator to the radiator.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
