305 to 350swap wire harness
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 to 350swap wire harness
Unless your changing induction system to something other that what the 305 is the harness will work.
Engine: Lb9
Transmission: M20
You can modify your harness or sell it and strip down one from the junk yard. You need switched ignition to your distributor, alternator, ignition switch to starter solenoid, you didnt state if you have a automatic for tcc lockup or manual trans. Depending if this was tbi or tpi rewire for a manual fan switch or better install a single wire grounding coolant temperature switch to control the fan. Do a search there is a thread on converting from if to carb.
Sanjay
Aug 12, 2015 03:41 PM
