7.4 vortec to a carb into a 92 rs camaro
Car: 1992 RS Camaro
Engine: 355 SBC
Axle/Gears: Stock
i am tearing down a 7.4 1996 vortec to rebuild it into a 7.4 maybe bored .030 over but i was wondering if it was possible to convert it to carb an if so what are the steps an items needed to make it happen im going to put it into a 92 camaro an make it a prostreet car so leading to my other question what parts to i need to prepare the car for the swap an parts needed to complete the swap
joshuatjtorres@gmail.com
what parts will i need for the engine heads intake pistons timing chain cam lifters
Car: 1989 IROCZ
Transmission: 5 spd
Axle/Gears: 3.45? G92 Option
Re: 7.4 vortec to a carb into a 92 rs camaro
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A simple large cap HEI is a self contained distributor. All it needs is a good ignition power source to work.
Is the vortec a non adjustable valve train? I thought only the Gen V engine had non adjustable.
Other than switching from EFI to carb and using a non computer controlled distributor, dropping in a 7.4 Vortec is no different than dropping in any other BBC into a third gen. There's just a lot less sensors that you'll need without a computer.
Car: 1992 RS Camaro
Engine: 355 SBC
Axle/Gears: Stock
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
The fuel pump should be different, the '96-'00 Vortec 7400 should need 38+ psi, where the '90-'95 was TBI, and that was like 12 psi. Before '90 should be carb, IIRC, and that should be 3-5 psi. The oil pump should be fully interchangeable from '65-'00, as I understand it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
